1 - 19 of 19 Posts
I have a 2008 GXP automatic with 71k miles. When the weather is below 60 degrees F, a weird noise appears to be coming from the engine. It sounds like a high pitch version of Chewbacca from Star Wars. It makes this loud noise when it is sitting idle and also when accelerating and decelerating. Really no rhyme or reason as to when it makes this noise. When the weather is warm (above 60 degrees) it does not make the noise. Does anybody have any thoughts?
Thanks!
High pitch points me toward an air leak, possibly one of the connections to the intercooler......but you'd hear that only under boost. Not sure why its only when its cold?
Record the noise with your phone, post it to YouTube and share the link here so we can hear what we're dealing with.
This could result from any number of things. Squealing accessory drive belt (or accessory), air leak as previously mentioned, bad tensioner, something loose that is sitting too close to the accessory drive system, bad AC clutch (though that's a bit of a stretch), your turbo tearing itself to pieces (or just being loud due to an opening in the intake tract)...
Your throttlebody to charge pipe hose looks really far away from being "hubbed"
Are you missing the hose that connects to the other red circle?
What he said ^
The valve cover vent hose has broken away from the air intake tube (not good) at Saveaux's top red circle, and the throttle-body rubber hose is nowhere near being fully attached to the aluminum pipe at the bottom circle.
The noise sounds like a rattle to me, but it could well be air blowing out of that throttle-body intake and making a 'raspberry'.
Fix those two things and see if it clears up. The second is an obvious and easy DIY fix. The first has happened to plenty of folks - usually when they pull the lid to change the air filter without first unclipping the braided hose. Folks have either replaced the whole air intake tube (expensive), replaced it with and aftermarket metal one (DDM or Werks - also not cheap) or simply glued the nipple back on the intake tube. Many, many threads on this issue - do a search.
Discussion Starter #11
I noticed that the plastic nipple had broken off and is inside the hose connector. I removed the broken nipple and not sure if it is able to be super glued back on, but I will try. See the picture.
Any other suggestions? Do you thinks this is the cause of the weird noise?
Thanks
Discussion Starter #12
What he said ^
Here is a better picture of the throttle-body rubber hose in Saveaux's bottom red circle. Does this look correct?
Discussion Starter #13
Ok...I have repaired the valve cover vent hose and it is now connected back to the air intake tube. The noise still persists. I looked closer for the source. It appears to be some sort of vibration coming from the alternator. I touch the alternator while it is making the noise and can feel the vibration. Has anyone seen this before? Is the alternator going bad? 71k miles. Thanks again!
AC compressor? It doesn't really sound like a bearing failure, but couuld be.
You could try taking the accessory belt off and running the engine to see if the sound goes away.
Alternator bearing, verify by putting a long solid object (screw driver) on alternator housing and hold the other end to your ear. You'll hear and feel the vibration.
Your throttle hose isn't all the way onto the intake pipe. That depressed section just to the left of the hose in your last picture is where the clamp is supposed to be.
1 - 19 of 19 Posts
