Mechanical
-ZOK suspension and D52 rear spoiler
-Car was delivered from GM with no rust proofing and it was immediately built as a race car, no street miles, no rust
-< 7500 Total Miles
-Current weight 3037 lbs., w/ 190 lb. driver
-Top is carbon fiber and weigh is < 5 lbs.
-Street legal with clear title and emissions test for Ohio
-Well balanced car with neutral handling
-Engine oil cooler mounted in front of regular radiator
-No air conditioning. Fan, heater and defrost work well
-Custom 3” stainless exhaust and CAT replacement down pipe
-Front Brembo brakes with large 315 mm rotors w/ brake ducts. Original fog lamps are available
-Custom TIG Welded Pro Mc Mahan cage, with door and dash bar
Race Performance
-Track records - Nelson Ledges (1:12.945), Mid Ohio (1:38.2), Gratton (1:27.50), Indy (1:45.636) and Gingerman (1.88M = 1:33.087, 2.14M = 1:43.033)
Suspension
-Penske 8760 double adjustable shocks with remote nitrogen reservoirs
-Rear shocks have adjustable damping that is cockpit adjustable
-Custom Mona ball suspension mounts
Interior
-Remote activated Fire system.
-RaceTech seat with halo, FIA rated
-Left window, center and right window nets
-Simpson Platinum 6 point harness (current dates), with pro mounting
-Gauges added for oil pressure and differential oil temp. Both are backlit for night use too.
-Differential cooler with Weldon pump and radiator in the back of the car.
-Racing steering wheel with quick disconnect
-Custom switch plate with lights to run differential pump, fan, AMB transponder and data system. This panel also has the DIC switches to run all stock functions from Pontiac like mileage, boost, water temp. etc.
-Original Pontiac seats are available.
-Lexan pop in windows fit in the doors when it rains.
Exterior
-Custom flame vinyl graphics package. This can be removed easily with a heat gun
-Tires 275/35/18, several used sets of Hoosiers available
-8 - Wheels - Forgeline ZX3R, 18 lbs. each, with special inner rim and titanium fasteners. Special wheel race offset and race spacers front and rear increase track
-4 - Stock Pontiac Solstice rims with Hoosier rain tires
-ARP-100-7702 7/16-20RH long NASCAR wheel studs and Gorilla lug nuts
$22,500 Bill 440-821-6421 or 440-543-9545 EST. [email protected]
-< 7500 Total Miles
Race Performance
Suspension
Interior
Exterior
