2021.04.11 Brake Redux and Seating
I really needed to get shorter brake hoses after putting the sway bar back on the car and seeing how close it was. I did a poor job of estimating how much longer I needed. Bottom line is that if you put on the Brembo calipers, you need no longer than 16 inches, from tip to tip of hose. Given a hose has from 1/4 to 1/2 inch fitting past the mounting bracket, the bracket to hose banjo is 15.5 or so, no more. If you get them custom made, I'd say you should ask for 15.75 inches tip to tip.
- Inspect the banjo fittings carefully, if they bend them by themselves as your shop. One set I got had a slight pull from getting a near 90 degree bend on too short of a stem, and it deformed the banjo head. I had to take a long time to both compress with a grade 8 bolt, and file the un-flush face very gently, to where I was comfortable that I could mount them without overtorqueing an aluminum caliper. Copper washers are malleable but not to an extreme degree without a lot of force.
- Check the clocking of the chassis side fitting, if it's asymmetrical. The first set I got had a generic "no clock" fitting that was round, and not ideal as it required 2 wrenches to tighten or loosen the line (as your getting brake fluid dribbled on your hand, not fun and very slippery). The second set I got had a "Toyota" fitting which was like a hex but 2 rounded sides. This didn't fit as it was too big, and I needed to round a different side in order to clock the banjo head to the right orientation. I can't say how to clock it, you need to take the bracket, or just accept you'll need to grind it, if you get this fitting type.
- I also put plastic wire loom around the hose as a protective sleeve.
- I also rounded the ends of the swaybar to remove the possibility they would catch the hose by a corner of the bar.
The passenger side seat bracket is done and the seat is in. Saved 5 pounds by using a different design. No foward/back adjustability at all though.
Now it can get test driven and inspected, and ready to roll!
I think also along the way I replaced the intercooler silicone hoses to be able to push the aluminum tubes down further, they were touching the hood. Got some by the inch for really cheap, you just have to search. A Kappa vendor was "out of stock" and that seemed odd as its so ubituquous.
I got a set of junkyard hood vent ornaments, and had to dechrome them by hand (easy) and warm one up a hellalot to take the incorrect bend out of it, was probably bent in a crash or something. Made a nifty way to unbolt them from the hood for autocross ventilation with some clip-nuts.
Sway bar:
Sad banjo fitting:
Brackets:
Faces covered to protect the innocent, haha! My wife is actually a great help.
