1 - 9 of 9 Posts
david052874 said:
this article I found states that you can get a supercharged Solstice with 220hp. Is this an aftermarket charger that we must put on or does this come from the factory? Everything I have seen says it is 170 hp out of the dealer.
http://www.autointell.net/nao_companies/general_motors/pontiac/pontiac-solstice/pontiac-solstice-02.htm
Welcome to the forum,
The Solstice that will be coming from the factory is 177bhp. There MAYBE a higher output model but probably as a 2007 model. There will be aftermarket people offering either S/C or Turbo for the SOL/SKY.
By the way that article was the original concept car from 2002 and it is not the production model.
Primus
I am located in St. Louis also. Which of the dealerships did you order your
Solstice from?
St Louis here, too. Well, Belleville, actually.
Stonebreaker, I don't see you on the confirmed list. Did you get one of the first 1000?
Nope. I didn't even know about it until it was already over.
The article actually says 240HP not 220HP, and it's a review of the 2002 Concept Solstice. That engine combination currently does not exist.
I'm personally hoping GM Performance Parts is going to give me some addon lovin, but I fear they're going to forget about me and focus on whatever the high output version will be. :(
1 - 9 of 9 Posts
