Hello,
I'm sure this solution is somewhere, but I wanted to describe the problems and solutions I found. And concerns I guess in case someone else has this problem. In all honesty I can't remember 100% if I bought the yellow charge tubes from DDM. It was 13 years ago and my memory sux. It could have been another company and I can't remember.
Anyway, for those that saw my last post, I was having problem installing the new 3 bar sensors.
Problem 1: First off, they were too small and didn't line up.
Solution 1 With the help of everyone (thank you) I was told to remove the metal bushings, they now fit/lineup.
Next problem, I didn't get the new o-rings with the purchase so the sensors rattles around and would leak. Solution, I got the o-rings off of Amazon.ca
OK..cool. Now with the new o-rings installed the manifold sensor popped in, no fuss, don't forget to lube her up boys! (nothing sexual intended, but you take it has you may)
Problem 2. The intake sensor would NOT fit with the new o-rings NO MATTER how much I lubed it, or twisted and pushed. In fact I cut through a few o-rings and messed them up. Well I had 25 to try until I got it right... right? (I guess that's why they sell them in packs of 25 LOL)
So next morning (Yeah this happened Friday night after a really tiring week. Of course sh!t would go wrong)
Took a look after some rest. Pulled the charge tube off. I also looked at my wife's solstice (I know "his" and hers", I'm still pissed off she bought it. No room in the garage now) and I noticed the stock tubes aside from the hole for the sensor being a little bigger (maybe I didn't measure it) it had a "chamfer" along the edge!
Well... that would explain why I was chewing up o-rings like a bad of chips on a Friday night (my favourite pass time)
Solution 2: Luckily I have a small metal shop in the basement and a chamfering bit that just fit perfect. Did I say I pulled the charge tube off? Using a portable drill I carefully gave it a chamfer like the stock tube. Looking inside I also saw a layer of powder coat in the hole.
So taking the right size punch I wrapped some sand paper around it and removed the power coat to the bare metal. Something I noticed (look at the picture) the inside of the hole is scored!
I'm not a professional machinist by any stretch of the imagination but I'm sure I could have done better! But I had no intention of removing them since they would throw of the size of the hole too much...so using some steel wool I smoothed and polished the chamfer and hole best I could.
Before putting it back on I ran a towel through the tube a few time to get rid of the bits and pieces of metal. Something that I'm told would have been evident when I first bought it.
I didn't want to try the sensor until I had it on... I wanted the pleasant surprise or feeling of defeat to hit me with the tube back on the car. (I know... I need a therapist)
Incidentally, I tested the 3bar with the new o-rings on my wife's car with the stock tubes. FITS LIKE A GLOVE... a little silicon grease and pops on no effort.
So... the big moment of true. Lubing up the new intake sensor with the correct o-rings, I placed it over the hole and gave it a gentle push...
Yup.. popped right in like my wife's stock charge tube.
So at this point I figured I had finally won the day. I had defeated the monster and saved the "damsel in a dress".
Guess what?
PROBLEM FRICKEN 4!!! I can't open my new 3 bar tune from Lydon because I have the OLD SOFTWARE (I know, you warned me) and I need to upgrade for $289.
OK... I decide, yes I will do that. Checking the HP Tuner site I see that they are out of stock because
"Due to supply chain challenges, device upgrades are not currently available."
So I put the stock sensors in, and I'm sitting here writing this to vent and cry at the same time, while thinking to myself. Is it worth it?
So no Solution 4
202 Viton O-Ring, 75A Durometer, Black, 1/4" ID, 1/2" OD, 1/8" Width (Pack of 25) : Amazon.ca: Industrial & Scientific
www.amazon.ca
Guess what?
So no Solution 4
