1 - 8 of 8 Posts
All the pre-into hype and current lit mentions a near perfect 50/50 weight bias. However the Motor Trend head to head test shows a calculated 53/47, front to rear bias, just like the Miata. Is this a misprint? Has anyone weighed their front and rear, with and without driver and/or passenger? The results would be interesting.
Unless they have made a major change in the Miata, I question their weight stated balance. My 2000 Miata was extremely rear end light. It couldn't have been anything like the ratio posted. I would put two 50 pound bags of sand in the trunk for winter traction and the car would handle really well, except for no power. Without the sand it was a bear in the turns. Lots of brake and no gas if you didn't want to be looking in the wrong direction before you exited the turn.
The weight distribution for both cars is correct. Unladen, full fuel tank, (called "Curb"), the cars are approximately 52.5% front.
Each occupant subtracts about 1% from the weight distribution. With two occupants and full fuel tank, both cars are right around 50%.
Also if you read all the refrences to the 50/50 weight distribution values given by both Mazda and GM they always word it as "Near 50/50" or "50/50*" with a definition of * beaing "Near."
Another thing. Compared to most cars, the Solstice is relatively light. 52/48 is only about a 120 pound difference. A full tank of gas alone would put it below 51/49.
Sounds like an alignment problem.
The balance is not exactly 50/50 as tested by Mallett before the conversion, but more in the 53/47 range as magazine tested. Mallett didn't change the front to rear balance much over the factory setting, but a little better (52.7/47.3). What he did do was balance the car left and right to a 50/50 balance with a 200 lb driver and 1/2 tank of gas making the car handle more predicatively on left and right turn-ins.
1 - 8 of 8 Posts
