1 - 15 of 15 Posts
I think the Sky guys are leading the charge for performance
I love it oh and the injector controller can be had quite cheaply if you use an ftc-e from URD. I used the controller on my turbo tacoma and it was quite handy
If someone would, please, give us rookies the cliff-notes version of what this will do for performance. Thanks!
This will solve some fueling issues encountered when making more power and it will keep your intake valves clean and prevent buildup.
Thanks. I mean, who knew! I never would have thought of adding a 5th injector without having a 5th cylinder for it. I guess you gotta think outside the box. And know something about cars and engines. I may go with this in the future. I've had my GXP for 5-1/2 years and just now getting around to working on mods.
Would you still continue to spray methanol as well with this 5th injector? Will this provide more fueling than methanol?
Methanol? or do you mean Ethanol? Yes the fuel injector is fed from the stock fueling system.
No what I mean is that I'm already spraying meth with the aem meth kit in the cold side charge pipe after the tmap sensor. Would I get rid of the meth kit if I ran a 5th injector?
Can the controller that comes with the aem meth kit be used as the controller for the 5th injector setup?
It probably can but seeing how well it will work is unknown. The Devils own has been used and proven to work well with out a hitch.
NP, I bought all the hardware, Fuel injector and Controller, just waiting on the machining and welding to happen to install. Let me know if you have any questions, those I don't know I'm sure John will chime in.
1 - 15 of 15 Posts
