1 - 5 of 5 Posts
got a service message from my local GM dealer reminding me of the 60,000 miles service.what is done other than oil change,and is it stuff i can do at home?
My Owner's manual says, if you don't have a DIC, it's time to change the oil. Next on the list is inspect the engine air filter, replace if needed, and rotate the tires. A pretty short list.
Also, brake/clutch fluid should be replaced every two years. If you have ABS, do NOT let air get into the system, or you will have another trip to the dealer.
Discussion Starter · #5 ·
i should be good then,had the brake system flushed/new fluid last year and cooling system was done when new t-stat was installed 2 years ago.
1 - 5 of 5 Posts
