81 - 100 of 140 Posts
Discussion Starter #81
Page 58
The Solstice GXP's Ecotec turbo spits out 260 high-spirited horses and . . . . . from just two liters of displacement . . . . That's a remarkable 130 bhp per liter: the highest specific-output engine GM has ever produced.
Interweb image
Engine components
Discussion Starter #82
Page 59
Page wide photo . . . . GXP's 260 horses and torque make it one of the best performance values on the road.
Interweb image
Discussion Starter #83
Page 60
The pistons are subject to a lot of heat flux due to the high power density, so we went to what's called a 'salt-core' piston with oil galleys and oil-jet cooling . . . . . . . . . . . . . . The unique dual-scrolled turbocharger, which keeps exhaust pulses from cylinder #1 and #4 separate from those of cylinders #2 and #3 until they enter the turbine housing, delivers up to 20 psi of boost with nearly instant response. There's virtually no lag with this system.
Interweb image
ECOTEC Turbo engine
Discussion Starter #84
Page 61
The turbocharger itself is oil cooled for long life, and its compact design allows tight packaging. The 2.o turbo engine produces 83 more horses than the 2.4, yet delivers nearly the same fuel economy.
Interweb image
Discussion Starter #85
Page 62
"The 260 bhp Ecotec turbo didn't exist when we started," notes Performance Manager Dean Perelli. "And this is its first application, so the challenge came in developing a brand-new engine and integrating it in-to the Solstice. It's a joint venture among General Motors subsidiaries in Germany, Sweden and Italy."
Interweb images
The turbocharger
Discussion Starter #86
Page 63
Chain-driven camshafts means there's no belt to replace. Sodium-filled exhaust valves deal with high temperatures and 9.2:1 compression ratio adds to engine's efficiency.
Interweb image
Typical sodium filled exhaust valve
Page 63
And if one happens to be an idiot, they can also do a fair bit of damage. Watch this twit drop one into water.
Discussion Starter #88
Page 64
The GXP uses the same-sized wheels as the standard car, but the tires have a higher speed rating and a directional tread design with a three-season rubber compound. the GXP tires thus gave a better dry-road handling.
Interweb image
Discussion Starter #89
Page 65
The GXP logo appears in the speedometer and on the deck lid. Easiest way to identify a GXP, though is by its D-shaped brake-cooling intakes.
Interweb image
Discussion Starter #90
Page 66
Page wide shot of a Wilmington worker busy with the front facsia of a silver Solstice.
Interweb image
stupid question hear...why does the gxp list less head room??? liner??thicker seats??? or just because the gxp owners have bigger heads???:eek::giggle: just messing on that one(I wish I had a less head room) but why to less room? very nice thread.keep it up.
Definitely bigger heads. Or the fact that the height-adjustable seat does not go quite as low as the non-adjustable seat.
Discussion Starter #93
Good observation. On the long spec list, of which I clearly picked only a few, I intentionally picked some because they had unexpected differences between Base and GXP. Fuel tank has some surprises too. Different tank ? Different pump ? Incorrect data ? Typo ?
The fuel system is different to make it lower profile to fit under the coupe "trunk" liner, but I do not know which specific parts are different, and how much is just different arrangement.
Discussion Starter #95
Not needing the mahan-temple to support the glass rear window when the top is down possible also allowed that height to be lower.
Discussion Starter #96
Page 67
On 4 January 2004, two years after Pontiac introduced the Solstice concept at the Detroit auto show, GM displayed a nearly identical-looking but totally different Solstice and announced to the world that this car would enter production in 2005 as a 2006-model. Assembly would take place at GM's venerable plant in Wilmington, Delaware, an announcement that brought shouts of joy from both Wilmington and Detroit.
Interweb image
Bob Lutz introducing the Solstice production model. Detroit January 4 2004.
Discussion Starter #97
Page 68
We even added a third shift in January 2006. Our line rate is seven cars an hour, so to hit our target of 156 cars a day, we needed three shifts. Fortunately we've been able to pull in people from the Linden (New Jersey) and Baltimore assembly site . . .
Photo by forum member Lil'Oggi
Poster at the Wilmington assembly plant, photo taken July 2009, showing production numbers that were only achieved in Aug and Sept 2007
Discussion Starter #98
Page 69
Originally we thought the Solstice was going to be built at Mexico. At the same time, [assistant chief engineer] Bruce Kosbab was still developing the car, so we were working in parallel. Every time he'd have some change, we had to reflect that back into the build process. Then in April 2003, we got notice that we were switching plants to Wilmington DE.
Interweb image
Discussion Starter #99
Page 70
Page wide photo. Operator uses a lift device to help install the driver's bucket seat.
Interweb image
