1 - 20 of 28 Posts
About the only wheel that I found and liked is made by Axe....CS Lite in hyper black. How hard is it to change out our hubs for a 5x112 instead of the awful 5x110 that we have? If I'm spending $800 to redrill wheels, I might as well put that toward putting new hubs on this awful setup they used.......
redrill the hubs instead
Bill
And the rotors.
Alternatively, you can buy wheel adapters for almost any 5-lug pattern you want, but then you need to re-calculate your offset. There are quite a number of us Auto-Xer's that run the rear wheels off of the C6 Corvette. Plenty wide, light, cheap, and readily available for any bank account. Plus there is no need for further machining should you need to replace something in the future.
I've thought about wheel spacers, but my father's older Mustang convertible (84 IMSMC) had the 4 bolt lug pattern and they put 5 bolt on them in mid 90's and I remember nothing but issues with them. He had to tighten the wheels every 100 miles...it was awful. He actually lost a wheel on it because it came loose. I'd rather just find a hub that fits and has a 5x112 pattern and replace the rotors too. Everything out there that fits our cars looks so trucky or blingy or cheap that it's hard to find a rim I like. Or they're machined or are black and machined aluminum. I'm tired of the 5 star pattern too. I find one and it's only available in 5x108 or 5x114...it's ridiculous. One rim I found comes in 5x108, 5x112 and 5x114....another comes in 5x110, but the center bore is too big or the offset is like 20. You'd think for as many cars out there with the 5x110 that it would be easier to find wheels. So far the only one I've found is the Axe CS Lite in hyper black and they're hard to find in the 5x110, but I did manage...problem is with that is that they're $325/wheel vs. the normal price of $200 everywhere else for the 5x112. I'm not paying an extra $500 for wheels!!
Replacing the rotor and hub is going to cost $200 per corner, or $800 total, and that assumes that you can even find parts that fit everywhere else.
i still think redriling is an acceptable fix, and would be relatively inexpensive
Bill
But my point of replacing is that this opens up a whole lot more possibilities for different rims down the road. As far as redrilling....I don't want 5 other open holes in the wheels or mismatched spots. And I refuse to tighten my wheels every 100 miles like my father had to do with his mustang...it's just not worth the headache or the annoying looks.
i have spacers on the front of the corvette and they have NEVER loosened; but mine may be the exception
Bill
107688
107689
107690
I have never known spacers/adapters to come loose anymore than the wheel itself when properly installed (i.e. - never.) Albeit the difference in diameter between the spacer and rotor hat would drive me crazy in your picture Bill. As I machined mine myself I matched all the diameters between rotor hat and wheel seat and had them anodized black so they aren't as noticeable.
Swapping to a hub with a 5x112 pattern is not as simple as you're trying to make it. I don't believe the kappa unit bearings can be separated, so it would need to bolt to the knuckle, and use the same or a very similar tone ring signal if you still have ABS/ESC and want it operational. Then it needs to match the center bore of the wheel you choose (or be smaller and make/buy another adapter,) be available with the same spline as the solstice drive axles, have some sort of prevision for retention of the front bearing pre-load if it isn't designed in like the solstice ones, and be more or less the same overall length so your axles engage properly and the wheel centerline ends up back where it's supposed to laterally.
And then you'd still have to drill your rotors anyway.
For what you are trying to accomplish, you may want to look into PCD Variation Nuts, AKA "wobble nuts." Use at your own risk.
The other non-approved way is to take up that pesky 2mm (about 0.080") by simply lozenging the holes in toward the hub 0.040" per hole (best done in a computer operated milling machine).
But then the best way to do that safely is to convert to nuts with oval washers (like the old Cragar Uni-lug wheels) and machine the wheel for them.
Given all that, you would be better off trading your Solstice for a car that has more wheel options.
the reason for the need for the spacers is i changed the 62 Corvette OEM kingpin front suspension to a R&P independent IFS. Unfortunately the front track width of the new IFS was narrower than OEM and looked strange.... so, i was fortunate enough to find the machined billet spacers that are in the pictures and it brought the track out to where it needed to be. Oddly, the spacer studs are metric; so i have USS studs on the rear disc brakes and metric studs on the front disc brakes.....
i don't know why it has doubled the one picture
Bill
107693
107694
I have never used spacers on a car. But have had 2 inch spacer on my FJ Cruiser for almost 14 years now. The number one problem with using them was that the bearings would wear prematurely. I have 188K on the truck and it has done most of the tough off road trails west of the Mississippi. Roubicon, Kokopelli, Pancake Rock, Black Bear, Poughkeepsie and many many more. Never a bearing problem, nor have they ever came loose.
I have had problems finding wheels I like. Have been looking since I bought the car going on 6 years ago. Hate what I call the squished spider look. I just hydro dipped the stock wheels, carbon fiber. Have not found anything I would want to change them to yet. Doubt I ever will
Discussion Starter #14
Anyone with wheel knowledge.....with these fit?
18"
5x110
35 offset with 8.5" width (or can go 40 offset with 9.5" width)
72.1 center bore
Not sure if the offset is too large that it will rub anywhere....
18"
5x110
72.1 center bore
What size tire do you plan on running? Is your car lowered?
Our bore is 65.1mm so you'll need some 72.1>65.1 hub centric rings.
The 35 offset is a bit much but if you will run a 245 tire and the car is not lowered it will basically be flush with the fender, take a ruler to your stock rims/tires and see how much an extra 20mm will look like.
Discussion Starter #16
Yeah...stick tire...245/45/18
Discussion Starter #19
What is wrong with the stock rims? I think they look great myself. Save a whole lot of hassle!
Eventually the chrome starts to peel and will create air leaks. I have to put 5-10lbs of air in mine every 3 days and there is nothing they can do for it.
Discussion Starter #20
These are the 2 that I'm looking at....I would rather have the AXE over the ESR because of the color. Both are very similar. My other option is gloss black...which I could do with my black stripes....
107707
107708
1 - 20 of 28 Posts
