1 - 10 of 10 Posts
I was wondering if anyone else has this occur:
When you turn off the AC, but leave the recycled air turned on, does your AC really turn off, or is it still on?
It seems to me that if the recycled air is on, my AC is still on.
Yep, the compressor still cycles. The only reason I can think of is to ensure the seals in the A/C system don't dry up in the winter because oil isn't circulating through the system. This way, every time you run it in recirc, the A/C compressor runs. It probably runs in defrost no matter what as well.
Ac
What I've noticed is that whatever mode you were in ie... Heat/AC, if you turn off the fan it appears to switch to vent which inturn seems to continue blowing when the vehical is moving. To entirely turn off, I must turn the director to dash vents then close the dash vents.
Most cars cycle the a/c if you are in a windshield mode, but it shouldn't if you have it to vent. What happens if you turn the recycle off?
If you turn off recirc, the a/c compressor doesn't cycle. I noticed a small puddle under my car in one of the parking lots during the West Coast Meet. Upon closer observation, I realized that it was just water, but what confused me was that I hadn't been running my A/C or defrost. I had been running the heat in recirc because it seems to force more air out the vents that way. That's when someone else informed me that the compressor cycles in recirc. If you listen for it, you can hear it.
Discussion Starter · #7 ·
Thanks for the feedback. I think this answers my question. When I use the AC, it is certainly cooler than when it is off. I didn't realize the compressor stayed on when you turn off AC.
This is quite serious. I think a APB needs to be put out on this. Let GM know!
It makes sense, reclycle is really designed for a closed car, and using the cabins air. Without the a/c running ocassionally the windows would cloud up from the moisture in our breaths. Car as small as the sol it could happen quickly depending on the cercumstances.
1 - 10 of 10 Posts
