I have the NORM'S FIBERGLASS ZR-1 Fenders now I want to mount some
RED lights that would glow at night...I bought some from the truck stop nearby where i work at night
I have them mounted with some 3M Trim tape...what is the proper way to wire them up, I'd like these lights to be switched on when the side marker lights are on, but shut off with the key, I have tried the fuse jumper, it just wont shut them off Do I have to Tap into the Marker light and run the jumper
I have the little fuse jumper that will allow it to go into the fuse slot, run the accessory you are jumping and the small lights I am adding on.....Would it be better to wire them up to a small relay( i don't want to drill out a hole for a switch, just have them turn on with the parking lights.
Send a PM to me, Leave a detailed response to the post
Thanks !
Can someone here help out..... tell me how to wire them up, so nothing shorts out -- I have a total of 4 ( 2 on each side )
Thanks !
