1 - 7 of 7 Posts
Sorry I tried the google search but was unable to find a resolution.
Does anyone know how to adjust the top where it meets the windshield. The drivers side has about 3/16 more of a gap on the rubber bumpstop where the locating pins are compared to the passanger side. The passanger side has about 1/4 inch, does that seem right.
Again I apologize if this has been posted I couldnt find it, thank you
Also I tried adjusting the rubber bump stops when you have the top half folded down and it didnt seem to make a difference
This may help:
6. Tighten jamb nut.
Reactions: Rcocklin73
Is this what you adjust to stop the top from leaking at the latch? I'm thinking there may be too much tension on the top not allowing enough pressure on the rubber seals. Does this sound right?
Read the red text in the diagram. It explains what the two screws do.
Thanks for the diagram - very helpful. Mine was a bit out of alignment too, tighter on one side than the other. I think one side just drifted a bit over time, but it wasn't a big deal.
1 - 7 of 7 Posts
