41 - 43 of 43 Posts
Discussion Starter #41
Just an update, it looks like I will be going with a Tremec Magnum 6-speed. After visiting Tremec this week, (they are located about 5 miles from where I work) I was able to work out a local pick up price for a New TUET11012 trans and shifter for $3049.00. I ordered a trans cross member and mount from Performance werks, I will probably go junk yarding to look for a used 1998-2002 Camaro/Firebird Bellhousing, I should be able to reuse my existing LS2 flywheel, LUK Pressure Plate, and probably the clutch disc. This should only leave the slave cylinder, and drive shaft as known additional costs.
Discussion Starter #43
Are you saying that a Tremec Magnum 6-speed is not as strong as the original BW-T-56? If so I am confused as the Tremec is a beefed up smoother shifting T-56.
If I didn't understand you post please correct me.
41 - 43 of 43 Posts
