1 - 2 of 2 Posts
I've been reading many threads on deposits. Does the amount you leave as a deposit influence the ordering of these cars. For example, are you likely to get better treatment from the dealer if you leave a $1000 deposit than if you leave $500 or $250?
as always that depends on the dealer, but the answer should be no. The orders should be PUT IN when you come in and order.
The only exceptions is when your order is fully loaded, and the guy who ordered after you ordered a base model. And that only makes a difference if there is a constraint on the fully loaded cars options, in which case, your order has to wait until they can produce enough parts to fill it.
But all that still has absolutely nothing to do with the amount of your deposit.
1 - 2 of 2 Posts
