That's a new one on me. Maybe you were driving really fast in reverse and didn't know it.:lol:I got a good one for you all!!! I took my car in for this "light oil leak" this morning. I have oil all over the front of the motor, down the timing chain cover, all over the cross beam and all underneath the engine. It has not dripped on the driveway. It looked like it was coming from the WP access cover or just below it. The dealer calls me and says that it's the seal on my oil filter..... :willy: WHAT?!?!?!? How does oil from the back of the motor get all over the front?!?!?!?! So....I will pick up my car and see if they were "correct"... LOL... Could it possibly be the oil pressure relief vavle leaking?!?! :brentil:
Looking forward to an update. Remember I am here to look into anything further if you need my assistance.I got a good one for you all!!! I took my car in for this "light oil leak" this morning. I have oil all over the front of the motor, down the timing chain cover, all over the cross beam and all underneath the engine. It has not dripped on the driveway. It looked like it was coming from the WP access cover or just below it. The dealer calls me and says that it's the seal on my oil filter..... :willy: WHAT?!?!?!? How does oil from the back of the motor get all over the front?!?!?!?! So....I will pick up my car and see if they were "correct"... LOL... Could it possibly be the oil pressure relief vavle leaking?!?! :brentil:
Possibly. Another twist on your theory is mileage. Don't know how many miles you have on your sky, but as engines age if the seals are suspect (plus your added boost).......Certain motors are notorious for engine oil leaks, I know Bronco's usually always develop a rear main leak with age. Perhaps with your new seal they use a slightly better design or seal, problem solved. If it's the same darn seal, it could also mean that with enough miles, they leak will develop again...:willy::brentil:Alright, the problem child Red Sky will chime in:
A: Going to have to call BS on the Oil Filter Seal. Since as how our oil filters are cartridge style and on the back of the engine. We have seen the plastic cap seal go bad on a few cars, but if memory serves they always leaked all over the back of the engine; like one would expect.
B: The symptoms you are describing sound very similar to one of my many failures. A year or two after I started running the GMPP tune, I had an "oil leak" at the front of the engine that resulted in oil "mist" all over the front of the engine just like you described. It really never dripped very much, if any. Turned out to be the front main engine seal. Which on our cars, is very easy to change. The only time consuming part is disassemble of the front main pulley and serpentine belt, to gain access. Once that stuff is out of the way, there is cap that comes off the front main, and the seal is just a fricken rubber seal they switch out. Once fixed, the problem never came back. My theory is that the OEM seals may be right on the edge of tolerance, and the increased boost creates a little more crank case pressure (yes the venting system should keep it pressure neutral); so sometimes they fail.
No, I am not an Aerodynamics Engineer. But at a certain point common sense tends to kick in. Now maybe, just maybe there is a bizarre forward air velocity that circulates off the firewall and forward to the front of the engine. But if that was the case, one would think that would be rather counterproductive to how the coolant system works and how the IC works. Not to mention the entire underneath of the engine would have to be soaked, or else the oil would have had to magically float forward to the front of the engine without depositing any residue along the way. To me, this sounds like the spitter from the gravely road :lol::Do you know what air turbulence is like under the motor? Because I don't
Nice, exactly why I'm afraid to have to go to a dealer. Self-created oil leak from overfilling (by them). Now if you can actually get your motor all cleaned up you'll have to see if the leak stops.Well....when I took it in for them to fix and they told me it was the seal on the oil filter, I knew they didn't look. I checked my oil yesterday and it was 2 1/2 quarts overfull!!!! Nice job guys! There response was, I don't know how it got that full..... Right, just like you can't see the trail of oil running down the front of the motor!
Which is why we have our own experienced Kappa technician who knows how to maintain our cars correctly.:thumbs:Nice, exactly why I'm afraid to have to go to a dealer. Self-created oil leak from overfilling (by them). Now if you can actually get your motor all cleaned up you'll have to see if the leak stops.
Excellent, but will he do house calls? :leaving::lol:Which is why we have our own experienced Kappa technician who knows how to maintain our cars correctly.:thumbs:
