If you wanted to keep the stock head unit you could easily upgrade to a nice set of 3way 6 ½ inch coaxial’s in the doors and a set of 3 ½ inch for the rear.I've been curious about this as well since I don't really want to mess with taking the head unit out. I also don't have a Monsoon system so I'm curious as to what people would suggest for speakers that offer up a little more bass since I'm not that interested in putting in a sub at this point in time.
As much as I know about home audio, live audio and even audio in studios, I don't know a single thing about car audio as far as what speakers would be good for my situation and anything else I might need beyond the speakers.
But in all honesty you could probably upgrade the entire audio system for around $650. That would include new speakers all the way around, a stock GM Sub Enclosure with an 8” sub all powered by a 5-channel amplifier running off your stock head unit and you’d be much happier and blow the monsoon system away….
Just a suggestion….
If you don’t plan on adding a sub at this point then you can do a basic speaker swap and you’ll improve your system noticeably. But remember your head unit is still pumping out the same power regardless and most aftermarket coaxial’s draw more power, so at a lower volume the system will definitely sound better but don’t expect to be able to crank it up and have it blow the doors off without adding an amp.Would you suggest an amp if I went just the speaker route? Any brand suggestions as well? I'm probably going to just start off with the speaker upgrades this year, still not sure if I want to go the sub route yet. A lot of my "fun" money this year is tied up in other things so I figure swapping the speakers will be the cheapest thing for now.
Thanks for the suggestions!
I think you about answered everything. I do realize I'm limiting my output with the stock head unit but I like the way it looks and I don't want to dig into the dash to replace it nor do I want somebody else doing it. I think the amp with the speakers will be where I start and if it's still not up to par then I'll get a sub put in there next year. So now where are you located? My next big issue is finding somebody who I trust enough to tear the car apart to put the speakers in since I don't trust myself enough :lol:If you don’t plan on adding a sub at this point then you can do a basic speaker swap and you’ll improve your system noticeably. But remember your head unit is still pumping out the same power regardless and most aftermarket coaxial’s draw more power, so at a lower volume the system will definitely sound better but don’t expect to be able to crank it up and have it blow the doors off without adding an amp.
In regards to amplifiers the big issue in our cars is space, now there are people that have sunk there amps into the trunk but they still had to sacrifice trunk space to do it. After tearing our test car apart about 100 times we found that the Eclipse XA5000 5-channel amp works best for most people and it tucks nicely behind the drivers seat. It delivers a max of 50watt X 4 channels and a single mono channel at 150watts for the single sub. It is a class D amp so power consumption is cut down and there for so is the heat that is produced. Now some will argue that running two separate amps is better, actually I agree but the Eclipse does pack a good punch in a small form factor… In fact we had to line our Solstice with 8 cubic feet of Dynamat just to keep it from vibrating apart…LOL!
Let me know if there is anything we can do for you…
Martin-GMR
Martin - dude, your posts rock! Love that you guys are out there tearing the car apart.If you don’t plan on adding a sub at this point then you can do a basic speaker swap and you’ll improve your system noticeably. But remember your head unit is still pumping out the same power regardless and most aftermarket coaxial’s draw more power, so at a lower volume the system will definitely sound better but don’t expect to be able to crank it up and have it blow the doors off without adding an amp.
Martin-GMR
Yeah I agree, I'm glad there's guys that are doing this. I just wish some of them lived closer to me, I would gladly driver several hours and pay some extra cash to have somebody install speakers for me that knows their way around the Solstice. I have huge trust issues when it comes to my cars and as mechanically inclined as I am in other areas in my life I just don't know a single thing about tearing into cars beyond doing simple stuff like an oil change. It's one of those things where I just feel better paying somebody else to do it if they know what they're doing.Martin - dude, your posts rock! Love that you guys are out there tearing the car apart.
Thank you! As one of the founding members of the National GM Roadster Club I am really a Kappa enthusiast… The way I look at it is simply let me destroy my car and make all the mistakes so that you and our club members don’t have to….or ask me first because I’m sure I’ve made a mistake so that you don’t have to…. Plus it’s fun to rip the car apart add fun things like Nitrous systems, Building Custom Turbo kits, Tweak & Tune the car to get different results, Add audio components that most people wouldn’t event think of doing…. Then go tell people how to do all this!Martin - dude, your posts rock! Love that you guys are out there tearing the car apart.
