1 - 7 of 7 Posts
I was trying to use this picture as my avatar and somehow I must doing something wrong. Being technology challenged can someone help me?
Hey Michael. I downloaded the image to check it's size out to be sure it was under 100x100 pixels and when I tried to open it in graphics software I got an error that file is not valid "jpeg" format. It has the .jpg extension but something must be wrong with file itself. Did you by any chance change the extension (for example it was .gif or .bmp originally?)
edit: I changed your original file to .bmp (bitmap) and it opened. I re-saved it as .jpg format which should fix the file now. Try using this one instead. Right click this image and choose save image as.... and store on your hard drive, then upload as avatar.
Um... it had a .bmp extension before. Thank you so much mceb, you're the best. But then, I'm thinking you likely knew that!
1 - 7 of 7 Posts
