I just picked up an 07 base model 5speed and my backup lights aren't working. I've tried replacing bulbs and that's not it. I checked fuse 46 and it's good. I bought a replacement backup switch and am about to replace that. One question though: I pulled fuse 46 and when I put a meter across the terminals, with the key on and in reverse gear, I get 0V across the terminals. Would that be the case if the backup switch is faulty, of does 12V go across the fuse then to the switch and subsequently to the backup lamps?
Thanks.
Dr_S
Thanks.
Dr_S
