1 - 20 of 23 Posts
2008 Pontiac Solstice GXP
I thought it would be useful to have an easy way to lookup specifications for both the base model and the GXP. This is going to include Torque and Tolerance, Wheel Alignment and any other Specification I happen to come across.
This is not a complete list yet. I will be adding to it over the next week or so.
General Specifications
ApplicationMetricImperial
Axle Nut/Hub Nut215 N.m159 lb ft
Brake Bleeding SequenceRR-LF-LR-RF
Engine Mechanical
2.0L Oil Pressure (minimum at 1000 RPM)344.75-551.60 kPa50-80 psi
2.4L Oil pressure (minimum at 1000 RPM)344.75-551.60 kPa50-80 psi
Flywheel/Flex Plate/Drive PlateTorque
First Pass53 N.m39 lb ft
Final Pass25 degrees
Fuel System
2.0L Pressure Specification (In Tank Pump)395-464 kPa57-67 psi
2.4L Pressure Specification (In Tank Pump)345-414 kPa50-60 psi
Ignition
Cylinder Identificationfront 1-2-3-4 rear
Firing Order1-3-4-2
Spark Plug 2.0L
Gap0.9-0.75 mm0.035-0.030 in
Torque17-23 N.m12.5-17 lb ft
Spark Plug 2.4L
Gap1.1-0.95 mm0.043-0.037 in
Torque20 N.m15 lb ft
Wheel Lug Nut Torque140 N.m100 lb ft
Front Brake Tolerances
DescriptionMetricImperial
Brake Rotor Diameter296.00 mm11.653 in
Brake Rotor Discard Thickness*23.00 mm0.906 in
Brake Rotor Maximum Allowable Assembled Lateral Runout0.06 mm0.002 in
Brake Rotor Maximum Allowable Scoring1.50 mm0.059 in
Brake Rotor Maximum Allowable Thickness Variation0.025 mm0.001 in
Brake Rotor Minimum Allowable Thickness After Refinish23.50 mm0.925 in
Brake Rotor Thickness - New26.00 mm1.023 in
Rear Brake Tolerances
Brake Rotor Diameter278.00 mm10.945 in
Brake Rotor Discard Thickness*10.00 mm0.394 in
Brake Rotor Minimum Allowable Thickness After Refinish10.50 mm0.413 in
Brake Rotor Thickness - New11.80 mm0.465 in
*All brake rotors have a discard dimension cast into them. Replace any rotor that does not meet this specification. After refinishing the rotor, replace any rotor that does not meet the minimum thickness after refinish specification.
Brake Torque Specification
SuspensionApplicationMetricImperial
FrontBrake Caliper Bleeder Valve11 N.m97 lb in
RearBrake Caliper Bleeder Valve14 N.m10 lb ft
Front & RearBrake Caliper Bracket Bolt115 N.m85 lb ft
FrontBrake Caliper Guide Pin Bolt34 N.m25 lb ft
RearBrake Caliper Guide Pin Bolt27 N.m20 lb ft
Front & RearBrake Hose Fitting Bolt40 N.m30 lb ft
Front & RearBrake Rotor Screw10 N.m89 lb in
Wheel Alignment Specification
SuspensionCamberCamber Cross ToleranceCasterCaster Cross ToleranceTotal ToeSteering Wheel AngleThrust Angle
Front-0.50° ± 0.60°0.00 ± 0.60°8.00° ± 0.60°0.00 ± 0.60°0.10° ± 0.20°0.00°± 3.50°-
Rear-0.50° ± 0.50°0.00 ± 0.50°-4.00° ± 0.75°-0.10° ± 0.20°-0.00° ± 0.20°
Wheel Alignment Torque Specification
Front Tie Rod End Jam Nut60 N.m44 lb ft
Lower Control Arm Nuts165 N.m122 lb ft
Rear Tie Rod End Jam Nut60 N.m44 lb ft
Starting and Charging Torque Specification
Battery Cable Clip Stud10 N.m89 lb in
Battery Hold-Down Retainer Bolt25 N.m18 lb ft
Engine Harness Lead to Generator Nut20 N.m15 lb ft
Front Fender Rear Bracket Bolt20 N.m15 lb ft
Generator Bolt22 N.m16 lb ft
Negative Battery Cable Nut17 N.m13 lb ft
Negative Battery Cable Ground Bolt10 N.m89 lb in
Negative Battery Cable Ground Nut17 N.m13 lb ft
Positive Battery Cable Nut17 N.m13 lb ft
Positive Cable to Starter Solenoid Nut10 N.m89 lb in
Starter Bolt40 N.m30 lb ft
Starter Solenoid S Terminal Nut3 N.m27 lb in
Air Conditioning Torque Specification
Air Temperature Actuator Screw1.5 N.m13 lb in
Control Assembly Heater and Air Conditioning Screw1.5 N.m13 lb in
Mode Actuator Screw1.5 N.m13 lb in
Recirculation Actuator Screw1.5 N.m13 lb in
Recirculation Actuator Housing Screw1.5 N.m13 lb in
LNF (2.0) Tolerances
General Data
Engine TypeInline 4 Cylinder
Displacement2.0 L122 CID
RPOLNF
Liter (VIN)M
Bore85.992-86.008 mm3.3880-3.3887 in
Stroke86 mm3.388 in
Compression Ratio9.2:1
Balance Shaft
Bearing Clearance0.030-0.060 mm0.0012-0.0024 in
Bearing Diameter - Inside - Carrier20.050-20.063 mm0.7894-0.7899 in
Bearing Diameter - Outside - Carrier41.975-41.995 mm1.6526-1.6534 in
Bearing Journal Diameter20.000-20.020 mm0.7874-0.7882 in
Bushing Clearance0.033-0.102 mm0.0013-0.0040 in
Bushing Diameter - Inside36.775-36.835 mm1.4489-1.4512 in
Bushing Journal Diameter36.723-36.743 mm1.4458-1.4466 in
End Play0.050-0.300 mm0.0020-0.0118 in
Block
Balance Shaft Bearing Bore Diameter - Carrier42.000-42.016 mm1.6535-1.6542 in
Balance Shaft Bushing Bore Diameter40.763-40.776 mm1.6048-1.6054 in
Crankshaft Main Bearing Bore Diameter64.068-64.082 mm2.5224-2.5229 in
Cylinder Bore Diameter85.992-86.008 mm3.3880-3.3887 in
Cylinder Bore Out-of-Round - Maximum0.010 mm0.0004 in
Cylinder Bore Taper - Maximum0.010 mm0.0004 in
Cylinder Head Deck Surface Flatness - Longitude0.050 mm0.002 in
Cylinder Head Deck Surface Flatness - Overall0.10 mm0.0039 in
Cylinder Head Deck Surface Flatness - Transverse0.030 mm0.0012 in
Camshaft
Camshaft End Play0.040-0.307 mm0.0016-0.0121 in
Camshaft Journal Diameter26.935-26.960 mm1.0604-1.0614 in
Camshaft Journal Diameter - Front34.960-34.935 mm1.3774-1.3764 in
Camshaft Thrust Surface - with Camshaft Actuator Installed30.020-30.175 mm1.1828-1.1889 in
Connecting Rod
Connecting Rod Bearing Clearance0.029-0.073 mm0.0011-0.0029 in
Connecting Rod Bore Diameter - Bearing End52.118-52.134 mm2.0519-2.05252 in
Connecting Rod Bore Diameter - Pin End20.007-20.021 mm0.7877-0.7882 in
Connecting Rod Side Clearance0.070-0.370 mm0.0028-0.0146 in
Connecting Rod Straightness - Bend - Maximum0.021 mm0.0083 in
Connecting Rod Straightness - Twist - Maximum0.04 mm0.0157 in
Crankshaft
Connecting Rod Journal Diameter49.000-49.014 mm1.9291-1.9297 in
Crankshaft End Play0.050-0.380 mm0.0012-0.0150 in
Crankshaft Main Bearing Clearance0.031-0.067 mm0.0012-0.0026 in
Crankshaft Main Journal Diameter55.994-56.008 mm2.2045-2.2050 in
Cylinder Head
Deck Straightness - in 150 mm (5.91 in)0.05 mm0.0019 in
Deck Straightness - in 25 mm (0.985 in)0.025 mm0.0009 in
Between Head Bolt Holes0.030 mm0.0011 in
Surface Flatness - Block Deck - Longitude0.050 mm0.002 in
Surface Flatness - Block Deck - Overall0.1 mm0.004 in
Surface Flatness - Block Deck - Transverse0.030 mm0.0012 in
Valve Guide Bore - Exhaust6.000-6.012 mm0.2362-0.2367 in
Valve Guide Bore - Intake6.000-6.012 mm0.2362-0.2367 in
Valve Lifter Bore Diameter - Stationary Lash Adjusters12.013-12.037 mm0.4730-0.4739 in
Lubrication System
Oil Pressure - Minimum - @1000 RPM344.75-551.60 kPa50-80 psi
Oil Capacity4.8L5.0 quarts
Piston Rings
Piston Ring End Gap - First Compression Ring0.20-0.35 mm0.0078-0.0138 in
Piston Ring End Gap - Second Compression Ring0.35-0.55 mm0.014-0.022 in
Piston Ring End Gap - Oil Control Ring - Rails0.25-0.75 mm0.010-0.030 in
Piston Ring to Groove Clearance - First Compression Ring0.040-0.080 mm0.0016-0.0031 in
Piston Ring to Groove Clearance - Second Compression Ring0.003-0.068 mm0.0001-0.0027 in
Piston Ring to Groove Clearance - Oil Control Ring0.024-0.176 mm0.0009-0.0069 in
Piston Ring Thickness - First Compression Ring1.170-1.190 mm0.0461-0.0469 in
Piston Ring Thickness - Second Compression Ring1.471-1.490 mm0.0579-0.0587 in
Piston Ring Thickness - Oil Control Ring - Rail - Maximum0.473 mm0.0186 in
Piston Ring Thickness - Oil Control Ring - Spacer0.96-1.04 mm0.0378-0.0409 in
Pistons and Pins
Pin - Piston Pin Clearance to Connecting Rod Bore0.009-0.023 mm0.0004-0.0009 in
Pin - Piston Pin Clearance to Piston Pin Bore0.005-0.015 mm0.0002-0.0006 in
Pin - Piston Pin Diameter22.995-23.000 mm0.9053-0.9055 in
Pin - Piston Pin End Play0.320-1.278 mm0.0126-0.0503 in
Piston - Piston Diameter - @14.5 mm up85.967-85.982 mm3.3845-3.3851 in
Piston - Piston Pin Bore Diameter23.005-23.010 mm0.9057-0.9059 in
Piston - Piston Ring Groove Width - Oil Control2.001-2.003 mm0.0788-0.0789 in
Piston - Piston Ring Groove Width - Second1.52-1.54 mm0.0598-0.0606 in
Piston - Piston Ring Groove Width - Top1.23-1.25 mm0.0484-0.0492 in
Piston - Piston To Bore Clearance0.010-0.041 mm0.0004-0.0016 in
Valve System
Valves - Valve Face Runout - Maximum0.04 mm0.0016 in
Valves - Valve Seat Runout - Maximum0.05 mm0.0020 in
Valves - Valve Stem Diameter - Exhaust5.935-5.950 mm0.2337-0.2343 in
Valves - Valve Stem Diameter - Intake5.955-5.970 mm0.2344-0.2355 in
Valves - Valve Stem to Guide Clearance - Exhaust0.050-0.077mm0.0020-0.0026 in
Valves - Valve Stem to Guide Clearance - Intake0.030-0.057 mm0.0012-0.0022 in
Valve Lifters - Valve Lifter Diameter - Stationary Lash Adjuster11.986-12.000 mm0.0005-0.0020 in
Valve Lifters - Valve Lifter-to-Bore Clearance - Stationary Lash Adjuster0.013-0.051 mm3.2210-3.2299 in
Valve Springs - Valve Spring Load - Open - @22.5 mm525.0-575.0 N.118.025-129.265 lbf
Valve Springs - Valve Spring Load - Closed - @32.5 mm245.0-271.0 N.55.0782-60.9232 lbf
LNF (2.0) Torque Specifications
ApplicationMetricEnglish
A/C Compressor to Block Bolt22 N.m16 lb ft
Balance Shaft Adjustable Chain Guide Bolt10 N.m89 lb in
Balance Shaft Fixed Chain Guide Bolt12 N.m106 lb in
Balance Shaft Retaining Bolt10 N.m89 lb in
Block Coolant Plug15 N.m11 lb ft
Block Heater Bolt10 N.m89 lb in
Cam Cover to Cylinder Head Bolt10 N.m89 lb in
Cam Cover to Ground Cable Bolt10 N.m89 lb in
Cam Cover to Ground Cable Stud10 N.m89 lb in
Camshaft Cap Bolt10 N.m89 lb in
Camshaft Position Actuator Solenoid Valve Bolt10 N.m89 lb in
Camshaft Position Sensor Bolt10 N.m89 lb in
Camshaft Timing Chain Tensioner75 N.m55 lb ft
Catalytic Converter Bolt50 N.m37 lb ft
Catalytic Converter Bracket Bolt50 N.m37 lb ft
Catalytic Converter Nut50 N.m37 lb ft
Chain Guide Access Hole Plug90 N.m59 lb ft
Connecting Rod Bolt
First Pass25 N.m18 lb ft
Final Pass100 degrees
Coolant Jacket Plug35 N.m26 lb ft
Crankshaft Balancer Bolt
First Pass100 N.m74 lb ft
Final Pass125 degrees
Crankshaft Bearings - Lower Crankcase to Block - Bedplate
First Pass20 N.m15 lb ft
Final Pass77 degrees
Crankshaft Position Reluctor Ring15 N.m11 lb ft
Crankshaft Position Sensor Bolt10 N.m89 lb in
Cylinder Head Bolt
First Pass30 N.m22 lb ft
Final Pass155 degrees
Cylinder Head Front Chain Case Bolt30 N.m22 lb ft
Cylinder Head Oil Gallery Plug35 N.m26 lb ft
Cylinder Head Opening Plate Bolt10 N.m89 lb in
Drive Belt Tensioner Bolt45 N.m33 lb ft
Engine Coolant Temperature Sensor20 N.m15 lb ft
Engine Lift Bracket Front Bolt25 N.m18 lb ft
Engine Lift Bracket Rear Bolt25 N.m18 lb ft
Exhaust Camshaft Position Actuator
Exhaust Manifold Heat Shield Bolt25 N.m18 lb ft
Exhaust Manifold to Turbocharger Stud10 N.m89 lb in
Exhaust Manifold to Cylinder Head Nut14 N.m10 lb ft
Exhaust Manifold to Cylinder Head Stud15 N.m11 lb ft
Flywheel Bolt - Automatic Transmission
Flywheel Bolt - Manual Transmission
Front Cover to Block Bolt25 N.m18 lb ft
Fuel Pipe Bracket Bolt10 N.m89 lb in
Fuel Pressure Dampener Bolt10 N.m89 lb in
Fuel Pressure Sensor33 N.m24 lb ft
Fuel Pump Bolt - High Pressure15 N.m11 lb ft
Fuel Pump - High Pressure Line30 N.m22 lb ft
Fuel Pump - Low Pressure Line30 N.m22 lb ft
Fuel Pump Cover10 N.m89 lb in
Fuel Rail Bolts22 N.m16 lb ft
Generator to Block Bolt22 N.m16 lb ft
Ignition Coil Bolt10 N.m89 lb in
Intake Camshaft Position Actuator
Intake Manifold Brace Bolt22 N.m16 lb ft
Intake Manifold to Cylinder Head Bolt22 N.m16 lb ft
Intake Manifold to Cylinder Head Nut22 N.m16 lb ft
Intake Manifold to Cylinder Head Stud15 N.m11 lb ft
Knock Sensor Bolt25 N.m18 lb ft
Lower Crankcase to Block Perimeter Bolt25 N.m18 lb ft
Oil Cooler Bolts22 N.m16 lb ft
Oil Filter Adapter Cover22 N.m16 lb ft
Oil Gallery Gerotor Cover - Rear Bolt6 N.m53 lb in
Oil Gallery Plug - Cylinder Head35 N.m26 lb ft
Oil Gallery Plug - Rear - Block60 N.m44 lb ft
Oil Level Indicator Tube Bolt10 N.m89 lb in
Oil Pan Baffle Bolt14 N.m10 lb ft
Oil Pan Bolts25 N.m18 lb ft
Oil Pan Drain Plug25 N.m18 lb ft
Oil Pressure Switch26 N.m19 lb ft
Oil Pump Gerotor Cover Bolt6 N.m53 lb in
Oil Pump Pressure Relief Valve Plug40 N.m30 lb ft
Oxygen Sensor42 N.m31 lb ft
Piston Oil Squirter15 N.m11 lb ft
Power Steering Pump Bolt25 N.m18 lb ft
Power Steering Tensioner Bolt22 N.m16 lb ft
Spark Plug20 N.m15 lb ft
Starter Motor to Block Bolt53 N.m39 lb ft
Thermostat Housing to Block Bolts10 N.m89 lb in
Throttle Body Bolt10 N.m89 lb in
Throttle Body Nut10 N.m89 lb in
Timing Chain Adjustable Guide Bolt10 N.m89 lb in
Timing Chain Fixed Guide Bolt12 N.m106 lb in
Timing Chain Oil Nozzle Bolt10 N.m89 lb in
Timing Chain Tensioner Bolt10 N.m89 lb in
Timing Chain Upper Guide Bolt10 N.m89 lb in
Turbocharger Air Bypass Valve Cover Bolt/Screw7 N.m62 lb in
Turbocharger Air Cooler Outlet Pipe Bolts25 N.m18 lb ft
Turbocharger Brace Nut50 N.m37 lb ft
Turbocharger Coolant Feed Pipe Bolt20 N.m15 lb ft
Turbocharger Coolant Feed Pipe Mounting Bolt10 N.m89 lb in
Turbocharger Coolant Return Pipe Bolt20 N.m15 lb ft
Turbocharger Heat Shield Bolt10 N.m89 lb in
Turbocharger Nut30 N.m22 lb ft
Turbocharger Oil Feed Pipe Bolt20 N.m15 lb ft
Turbocharger Oil Return Pipe Bolt10 N.m89 lb in
Turbocharger Wastegate Regulator Solenoid Valve Bracket Bolt/Screw7 N.m62 lb in
Vacuum Pump Bolt10 N.m89 lb in
Vacuum Pump Bracket Bolt22 N.m16 lb ft
Vent Tube to Cylinder Head15 N.m11 lb ft
Water Jacket Drain Plug20 N.m15 lb ft
Water Pipe Support Bracket Bolt10 N.m89 lb in
Water Pump Access Cover Bolt10 N.m89 lb in
Water Pump/Balance Shaft Chain Tensioner Bolt10 N.m89 lb in
Water Pump Bolts25 N.m18 lb ft
Water Pump Drain Plug20 N.m15 lb ft
Water Pump Sprocket Bolt10 N.m89 lb in
LE5 (2.4) Tolerances
General Data
Displacement2.4 L146 CID
Liter (VIN)B
Bore87.992-88.008 mm3.4668-3.4675 in
Stroke98 mm3.861 in
Compression Ratio10:01
Balance Shaft
Bushing Diameter - Inside36.776-36.825 mm1.4479-1.4498 in
Block
Cylinder Bore Diameter87.992-88.008 mm3.4668-3.4675 in
Cylinder Head Deck Surface Flatness - Overall0.08 mm0.0031 in
Camshaft
Camshaft End Play0.040-0.144 mm0.0016-0.0057 in
Camshaft Thrust Surface21.000-21.052 mm0.8268-0.8252 in
Connecting Rod
Crankshaft
Cylinder Head
Lubrication System
Piston Rings
Piston Ring End Gap - First Compression Ring0.15-0.30 mm0.006-0.012 in
Piston Ring End Gap - Second Compression Ring0.20-0.45 mm0.008-0.018 in
Piston Ring End Gap - Oil Control Ring - Rails0.15-0.51 mm0.006-0.020 in
Piston Ring to Groove Clearance - First Compression Ring0.04-0.08 mm0.0015-0.0031 in
Piston Ring to Groove Clearance - Second Compression Ring0.030-0.070 mm0.0012-0.0030 in
Piston Ring to Groove Clearance - Oil Control Ring0.027-0.176 mm0.0011-0.0069 in
Piston Ring Thickness - Oil Control Ring - Spacer1.460-1.537 mm0.0575-0.0605 in
Pistons and Pins
Pin - Piston Pin Clearance to Connecting Rod Bore0.007-0.026 mm0.0003-0.0010 in
Pin - Piston Pin Clearance to Piston Pin Bore0.004-0.014 mm0.0002-0.0006 in
Pin - Piston Pin Diameter19.995-20.000 mm0.7872-0.7874 in
Pin - Piston Pin End Play0.410-1.266 mm0.0161-0.0498 in
Piston - Piston Diameter - @14.5 mm up87.967-87.982 mm3.4633-3.4638 in
Piston - Piston Pin Bore Diameter20.004-20.009 mm0.7876-0.7878 in
Piston - Piston Ring Groove Width - Oil Control2.51-2.53 mm0.0988-0.0996 in
Piston - Piston to Bore Clearance0.010-0.041 mm0.0004-0.0016 in
Valve System
Valves - Valve Stem to Guide Clearance - Exhaust0.050-0.077 mm0.0020-0.0026 in
Valve Springs - Valve Spring Load - Closed - @22.5 mm525.0-575.0 N.118.025-129.265 lbf
Valve Springs - Valve Spring Load - Open - @32.5 mm245.0-271.0 N.55.0782-60.9232 lbf
LE5 (2.4) Torque Specifications
A/C Compressor to Block Bolt20 N.m15 lb ft
Balance Shaft Adjustable Chain Guide Bolt15 N.m11 lb ft
Balance Shaft Bearing Carrier to Block Bolt10 N.m89 lb in
Balance Shaft Fixed Chain Guide Bolt15 N.m11 lb ft
Balance Shaft Sprocket Bolt50 N.m37 lb ft
Block Core Plug40 N.m30 lb ft
Chain Guide Plug90 N.m59 lb ft
Connecting Rod Bolt
Final Pass70 degrees
Cylinder Head Bolt
Cylinder Head Front Chaincase Bolt35 N.m26 lb ft
EGR Cover Bolt25 N.m18 lb ft
EVAP Canister Valve Bolt22 N.m16 lb ft
Exhaust Manifold Pipe Flange Stud16 N.m12 lb ft
Exhaust Manifold to Cylinder Head Nut - 2 passes14 N.m124 lb in
Exhaust Manifold to Cylinder Head Stud10 N.m89 lb in
Front Lift Bracket Bolt25 N.m18 lb ft
Fuel Rail Bracket Stud10 N.m89 lb in
Generator to Block Bolt23 N.m17 lb ft
Heat Shield to Exhaust Manifold Bolt22 N.m16 lb ft
Intake Camshaft Rear Cap Bolt25 N.m18 lb ft
Intake Manifold to Cylinder Head Bolt10 N.m89 lb in
Intake Manifold to Cylinder Head Nut10 N.m89 lb in
Intake Manifold to Cylinder Head Stud6 N.m53 lb in
Oil Filter Housing Cover22 N.m16 lb ft
Oil Gallery Plug - Rear60 N.m44 lb ft
Oil Level Indicator Tube to Intake Manifold Bolt10 N.m89 lb in
Oil Pan to Block Bolts25 N.m18 lb ft
Oil Pressure Switch22 N.m16 lb ft
Oil Pump Cover Bolt6 N.m53 lb in
Throttle Body Stud6 N.m53 lb in
Timing Adjustable Chain Guide Bolt10 N.m89 lb in
Timing Fixed Chain Guide Bolt15 N.m11 lb ft
Timing Upper Chain Guide Bolt10 N.m89 lb in
Water Pump Access Cover Bolt7 N.m62 lb in
Antilock Brakes Torque Specification
Brake Pipe Fittings at Brake Pressure Modulator Valve (BPMV)20 N.m15 lb ft
Brake Pressure Modulator Assembly Bracket Mounting Bolts10 N.m89 lb in
Brake Pressure Modulator Assembly-to-Mounting Bracket Bolt11 N.m97 lb in
Electronic Brake Control Module (EBCM) to Brake Pressure Modulator Valve (BPMV) Retaining Bolts2.3 N.m20 lb in
Body Panel Torque Specification
Battery Tray Bolts31 N.m23 lb ft
Front Fender Bolts10 N.m89 lb in
Hinge to Hood Nut25 N.m18 lb ft
Hood Latch Bolts25 N.m19 lb ft
Hood Striker Bolt10 N.m89 lb in
Hood Striker Bolts25 N.m18 lb ft
Wheelhouse Liner Bolts10 N.m89 lb in
Bumper Torque Specification
Front Fascia Bolts10 N.m89 lb in
Front Fascia Reinforcement Nuts10 N.m89 lb in
Front Fascia Support Bolts - Lower9 N.m80 lb in
Front Impact Bar Bolt9 N.m80 lb in
Front Impact Bar Bolts25 N.m18 lb ft
Rear Bumper Fascia Center Bracket Nuts3 N.m27 lb in
Rear Bumper Fascia Support Bracket Screws9 N.m80 lb in
Rear Bumper Lower Retainer Screws9 N.m80 lb in
Rear Fascia Bolts10 N.m89 lb in
Rear Fascia Bracket Bolts9 N.m80 lb in
Rear Fascia Bracket Nuts3 N.m27 lb in
Rear Fascia Support Outer Screws10 N.m89 lb in
Wheelhouse Liner Screws2 N.m18 lb in
Clutch Torque Specification
Clutch Actuator Bolts10 N.m89 lb in
Clutch Cover to Flywheel Bolts30 N.m22 lb ft
Clutch Pedal Bracket Bolt10 N.m89 lb in
Clutch Pedal Bracket Nuts10 N.m89 lb in
Cooling System Torque Specification
Air Cleaner Stud10 N.m89 lb in
Air Conditioning (A/C) Condenser Bolt9 N.m80 lb in
Charge Air Cooler Pipe Bolt7 N.m62 lb in
Coolant Heater Bolt10 N.m89 lb in
Engine Coolant Temperature (ECT) Sensor20 N.m15 lb ft
Exhaust Heat Shield Bolt23 N.m17 lb ft
Radiator Air Deflector Bolt9 N.m80 lb in
Radiator Bolt25 N.m18 lb ft
Radiator Surge Tank Bracket Nut9 N.m80 lb in
Radiator Upper Support Bracket Nut9 N.m80 lb in
Surge Tank Nut9 N.m80 lb in
Thermostat Housing Bolt10 N.m89 lb in
Thermostat Housing Cover Bolt10 N.m89 lb in
Turbocharger Coolant Feed Pipe Bracket10 N.m89 lb in
Turbocharger Coolant Feed Pipe Fitting35 N.m26 lb ft
Turbocharger Coolant Feed Pipe Bolt35 N.m26 lb ft
Turbocharger Coolant Return Pipe Bolt35 N.m26 lb ft
Water Pump Access Plate Bolt10 N.m89 lb in
Water Pump Bolt25 N.m18 lb ft
Water Pump Drain Plug22 N.m16 lb ft
Entertainment Torque Specification
AM/FM Radio Receiver Fasteners2 N.m18 lb in
Audio Amplifier Fasteners9 N.m80 lb in
Cellular Communication Antenna Fastener9 N.m80 lb in
Cellular Communication Microphone Fasteners2 N.m18 lb in
Communication Interface Module Bracket Fasteners9 N.m80 lb in
Communication Interface Module Fasteners9 N.m80 lb in
Digital Radio Antenna Fastener9 N.m80 lb in
Digital Radio Receiver Bracket Nut5 N.m44 lb in
Digital Radio Receiver Nut10 N.m89 lb in
Door Speaker Fasteners2 N.m18 lb in
Instrument Panel Wiring Harness Bracket Nut10 N.m89 lb in
Quarter Speaker Nut9 N.m80 lb in
Radio Antenna Bezel6 N.m53 lb in
Radio Antenna Bolt/Screw9 N.m80 lb in
Radio Bolt/Screw2.3 N.m20 lb in
Sub Woofer Box to Body Fasteners7 N.m62 lb in
Exhaust Torque Specification
Catalytic Converter Bracket Bolt/Nut (LNF)58 N.m43 lb ft
Catalytic Converter to Catalytic Converter Brace Bracket Bolt (LE5)50 N.m37 lb ft
Catalytic Converter to Catalytic Converter Brace Bracket Bolt (LNF)22 N.m16 lb ft
Catalytic Converter to Exhaust Manifold Nut (LE5)50 N.m37 lb ft
Catalytic Converter to Muffler Nut17 N.m13 lb ft
Catalytic Converter to Turbocharger Nut (LNF)58 N.m43 lb ft
Engine Mount to Frame Lower Nut (LNF)55 N.m41 lb ft
Exhaust Manifold Heat Shield Bolt (LNF)25 N.m18 lb ft
Exhaust Manifold Heat Shield Bolt (LE5)10 N.m89 lb in
Exhaust Manifold Nut14 N.m10 lb ft
Turbocharger Heat Shield (LNF)10 N.m89 lb in
Folding Top Torque Specification
Folding Top Clock Spring Shaft Nut11 N.m97 lb in
Folding Top Cover Number 1 Bow Retainer Screws2 N.m18 lb in
Folding Top Cover Number 1 Bow Screws10 N.m89 lb in
Folding Top Cover Number 3 Bow Screws10 N.m89 lb in
Folding Top Cover Number 4 Bow Screws10 N.m89 lb in
Folding Top Cover Rear Retainer Nut/Bolt9 N.m80 lb in
Folding Top Front Latch Handle Nut21 N.m16 lb ft
Folding Top Front Latch Screws9 N.m80 lb in
Folding Top Front Latch Striker Header Bolt8 N.m70 lb in
Folding Top Front Locating Pin18 N.m13 lb ft
Folding Top Front Locating Pin Guide Bolt25 N.m18 lb ft
Folding Top Link Nut25 N.m18 lb ft
Folding Top Pivot Bracket Nut9 N.m80 lb in
Folding Top Rear Latch Bolts25 N.m19 lb ft
Folding Top Rear Latch Bracket Bolts25 N.m19 lb ft
Folding Top Rear Latch Striker Bolt11 N.m97 lb in
Folding Top Rear Latch Striker Screw2 N.m18 lb in
Folding Top Rear Locating Pin/Locating Nut3 N.m26 lb in
Folding Top Rear Side Rail Ball Stud12 N.m106 lb in
Folding Top Rear Side Rail Cable Roller Screw3 N.m26 lb in
Folding Top Rear Side Rail Screw20 N.m15 lb ft
Folding Top Side Rail Assembly Bolts10 N.m89 lb in
Folding Top Side Frame Assembly Fasteners9 N.m80 lb in
Folding Top Side Front Weatherstrip Screw - After VIN 67Y1186522 N.m18 lb in
Folding Top Side Front Weatherstrip Screw - Prior to VIN 67Y11865210 N.m89 lb in
Folding Top Side Front Weatherstrip Retainer Screws9 N.m80 lb in
Folding Top Side Rail Link Bolt9 N.m80 lb in
Folding Top Side Rail to Number 1 Bow Screws10 N.m89 lb in
Folding Top Side Rail to Number 3 Bow Screws10 N.m89 lb in
Folding Top Side Rail to Number 4 Bow Screws10 N.m89 lb in
Folding Top Side Rear Weatherstrip Screw - After VIN 67Y1186523 N.m26 lb in
Folding Top Side Rear Weatherstrip Screw - Prior to VIN 67Y11865210 N.m89 lb in
Folding Top Side Rear Weatherstrip Retainer Screws9 N.m80 lb in
Folding Top Stow Strap to Inner Quarter Panel Fasteners9 N.m80 lb in
Upstop Jam Nut17 N.m13 lb ft
Frame Torque Specification
Frame Brace Bolts10 N.m89 lb in
Frame Brace Nuts10 N.m89 lb in
Front Closeout Panel Bolts9 N.m80 lb in
Front Wheelhouse Liner Bolts10 N.m89 lb in
Rear Crossmember Mounting Bolts100 N.m74 lb ft
Rear Suspension Lower Control Arm Reinforcement Bolts22 N.m16 lb ft
Rear Wheelhouse Liner Bolts10 N.m89 lb in
Transmission Mount Nuts55 N.m41 lb ft
Transmission Support Bolt58 N.m43 lb ft
Front Suspension Torque Specification
Lower Ball Joint Nut
First Pass40 N.m30 lb ft
Second PassPlus 135°
Lower Control Arm to Frame Nut165 N.m122 lb ft
Shock Absorber Lower Nut28 N.m21 lb ft
Shock Absorber Top Nut42 N.m31 lb ft
Shock Absorber Upper Nut47 N.m35 lb ft
Stabilizer Shaft Link Nuts72 N.m53 lb ft
Stabilizer Shaft Mounting Bracket Bolts55 N.m41 lb ft
Tie Rod End Nut
Second PassPlus 115°
Upper Ball Joint Nut
Second PassPlus 150°
Upper Control Arm to Frame Bolt110 N.m81 lb ft
Wheel Hub Bolt115 N.m85 lb ft
Horn Torque Specification
Horn Bolt10 N.m89 lb in
HAVC Torque Specification
A/C Refrigerant Valve11 N.m98 lb in
Bolt-A/C Compressor22 N.m16 lb ft
Bolt-A/C Condenser9 N.m80 lb in
Bolt-Distributor Air2.5 N.m16 lb in
Bolt-Hose Assembly - A/C Compressor and Condenser Hose22 N.m16 lb ft
Bolt-Radiator Assembly25 N.m18 lb ft
Bolt-Receiver Dehydrator Assembly6 N.m53 lb in
Bolt-Thermal Expansion Valve16 N.m12 lb ft
Bolt-Thermal Expansion Valve1.5 N.m13 lb in
Nut-A/C Condenser Tube9 N.m80 lb in
Nut-Air Inlet Housing9 N.m80 lb in
Nut-Distributor Air2.5 N.m16 lb in
Nut-Hose Assembly-A/C Compressor and Condenser Hose9 N.m80 lb in
Nut-Hose Assembly-A/C Evaporator16 N.m12 lb ft
Nut-Hose Assembly-A/C Evaporator Clip9 N.m80 lb in
Nut-HVAC Module Assembly9 N.m80 lb in
Nut-Tube Assembly-A/C Compressor16 N.m12 lb ft
Nut-Tube Assembly-A/C Condenser9 N.m80 lb in
Screw-Air Distribution Case1.5 N.m13 lb in
Screw-Air Inlet Housing1.5 N.m13 lb in
Screw-Air Outlet Duct1.5 N.m13 lb in
Screw-Blower Motor1.5 N.m13 lb in
Screw-Blower Motor Resistor1.5 N.m13 lb in
Screw-Evaporator Case Assembly1.5 N.m13 lb in
Screw-Heater Core Cover1.5 N.m13 lb in
Screw-Mode Actuator1.5 N.m13 lb in
Screw-Rear Air Outlet Duct1.5 N.m13 lb in
Screw-Receiver Dehydrator1.5 N.m13 lb in
Sensor-A/C Refrigerant Pressure5 N.m44 lb in
HVAC System Capacities
Abrupt Refrigerant Loss60 ml*2.0 oz*
Compressor Replacement74 ml**2.5 oz**
The Sanden PXV16 service compressor is used in this model year vehicle is precharged with 74 ml (2.5 oz) of PAG oil.
Condenser Replacement30 ml**1.0 oz**
Evaporator Replacement30 ml**1.0 oz**
Receiver Dehydrator Replacement30 ml**1.0 oz**
Total System PAG Oil Capacity118 ml4.0 oz
R-134a
Refrigerant Charge0.47 kg1.03 lbs
* Abrupt refrigerant loss due to large leak, hose rupture, collision, or pressure relief valve opening. Conditions that allow the refrigerant to seep or bleed off over time do not cause this oil loss. Upon replacement of a component that caused a large refrigerant loss, also add the required amount of oil for the particular component.
** If more than the specified amount of PAG oil was drained from a component, add the equal amount of oil drained.
Discussion Starter · #2 · (Edited)
Automatic Transmission Temperature Specifications
Temperature °CTemperature °FMinimum ResistanceNominal ResistanceMaximum Resistance
-40°C-40°F89500100000110500
-30°C-22°F464195140056381
-20°C-4°F251202761030100
-10°C14°F141601545016740
0°C32°F827889729666
10°C50°F500553915777
20°C68°F312033423564
30°C86°F200021322264
40°C104°F131713971477
50°C122°F888938988
60°C140°F613645677
70°C158°F432453474
80°C176°F310324338
90°C194°F228237246
100°C212°F170176182
110°C230°F128132136
120°C248°F98101104
130°C266°F777981
140°C284°F606264
150°C302°F484950
Automatic Transmission Torque Specification
Description of UsageRef No.*QtySizeMetricImperial
Accumulator Housing to Valve Body31812M6x1.0x30.011 N.m97 lb in
Channel Plate to Valve Body3007M6x1.0x38.011 N.m97 lb in
Converter Housing to Case27M8x1.25x35.022 N.m16 lb ft
Detent Spring Bolt---11 N.m97 lb in
Drain Plug to Fluid Pan631M14x1.5x10.020 N.m15 lb ft
Drive Flange Nut---60 N.m44 lb ft
Extension Housing to Case357M8x1.25x35.022 N.m16 lb ft
Fluid Cooler Pipe Brace Bolt---50 N.m37 lb ft
Fluid Cooler Pipe Retainer Bolt---25 N.m18 lb ft
Fluid Drain Plug---20 N.m15 lb ft
Fluid Fill Plug---20 N.m15 lb ft
Fluid Pan to Case6520M6x1.0x16.011 N.m97 lb in
Front Control Valve Body to Top Channel Plate502M6x1.0x38.011 N.m97 lb in
Input Speed Sensor to Case451M6x1.0x20.011 N.m97 lb in
Manual Shift Shaft Nut---9 N.m80 lb in
Oil Pressure Test Plug---11 N.m97 lb in
Output Speed Sensor to Case431M6x1.0x30.011 N.m97 lb in
Parking Pawl Actuator Bracket to Case6092M8x1.25x25.022 N.m16 lb ft
Prop Shaft Flange to Output Shaft341M22x1.5x10.057 N.m42 lb ft
Shift Control Assembly to Tunnel Reinforcement Nut---12 N.m106 lb in
Shift Control Linkage Adjustment Nut---9 N.m80 lb in
Torque Converter Bolt---63 N.m46 lb ft
Torque Converter Housing Seal Bolt2282M4x0.7x10.03.6 N.m31.86 lb in
Transmission Fluid Pump Cover to Torque Converter Housing2406M6x1.0x40.011 N.m97 lb in
Transmission Fluid Pump Cover to Torque Converter Housing2415M8x1.25x40.022 N.m16 lb ft
Transmission Level Hole Plug to Case361M18x1.5x12.020 N.m15 lb ft
Transmission Mounting Bolt M10x1.5---50 N.m37 lb ft
Transmission Mounting Bolt M12x1.75---75 N.m55 lb ft
Transmission Pressure Test Plug to Case401M10x1.0x8.011 N.m97 lb in
Valve Body to Case492M6x1.0x50.011 N.m97 lb in
Valve Body to Case516M6x1.0x50.011 N.m97 lb in
Valve Body to Case531M6x1.0x68.011 N.m97 lb in
Automatic Transmission End Play Specifications
Dimension BWasher Thickness (mm)Washer Thickness (in)
15.99 mm -16.27 mm (0.629 in - 0.640 in)0.95-1.050.037-0.041
16.27 mm -16.47 mm (0.640 in - 0.648 in)1.15-1.250.045-0.049
16.47 mm -16.67 mm (0.648 in - 0.656 in)1.35-1.450.053-0.057
16.67 mm -16.87 mm (0.656 in - 0.664 in)1.55-1.650.061-0.065
16.87 mm -17.07 mm (0.664 in - 0.672 in)1.75-1.850.068-0.073
17.07 mm -17.27 mm (0.672 in - 0.680 in)1.95-2.050.076-0.081
17.27 mm -17.47 mm 0.680 in - 0.688 in)2.15-2.250.084-0.089
17.47 mm -17.67 mm (0.688 in - 0.696 in)2.35-2.450.093-0.096
17.67 mm -17.87 mm (0.696 in - 0.704 in)2.55-2.650.100-0.104
17.87 mm -18.07 mm (0.703 in - 0.711 in)2.75-2.850.108-0.112
Automatic Transmission Clutch Travel Specifications
ComponentProductNumber of ClutchesMetricImperial
Reverse Clutch (404)5L40-E/5L50-E60.98-1.43 mm0.039-0.056 in
Direct Clutch (406)5L40-E81.41-1.86 mm0.056-0.073 in
Direct Clutch (406)5L50-E101.67-2.12 mm0.066-0.083 in
Low and Reverse Clutch (517)5L40-E101.72-2.17 mm0.068-0.085 in
Low and Reverse Clutch (517)5L50-E121.93-2.38 mm0.076-0.094 in
2nd Clutch (520)5L40-E101.47-1.92 mm0.056-0.076 in
2nd Clutch (520)5L50-E121.64-2.09 mm0.065-0.082 in
2nd Coast Clutch (528)5L40-E40.94-1.39 mm0.037-0.055 in
2nd Coast Clutch (528)5L50-E61.15-1.60 mm0.045-0.063 in
Intermediate Clutch (495)5L40-E61.13-1.58 mm0.044-0.062 in
Intermediate Clutch (495)5L50-E81.39-1.84 mm0.055-0.072 in
Overdrive Clutch (487)5L40-E/5L50-E61.60-2.05 mm0.063-0.081 in
Forward Clutch (436)5L40-E61.20-1.65 mm0.047-0.065 in
Forward Clutch (436)5L50-E81.41-1.86 mm0.056-0.073 in
Coast Clutch (438)5L40-E61.17-1.67 mm0.046-0.066 in
Coast Clutch (438)5L50-E81.43-1.93 mm0.056-0.076 in
Automatic Transmission Clutch Plate Specifications
ClutchNumber of Clutch Plates 5L40-ENumber of Clutch Plates 5L50-ENumber of Clutch Plates 5L40-E - GBG
Reverse Clutch (404)666
Direct Clutch (406)10108
Low and Reverse Clutch (517)101210
2nd Clutch (520)101210
2nd Coast Clutch (528)664
Intermediate Clutch (495)886
Overdrive Clutch (487)666
Forward Clutch (436)886
Coast Clutch (438)686
Automatic Transmission Reverse Clutch Housing Thrust Washer Chart
Dimension XWasher Thickness (mm)Washer Thickness (in)
50.18 mm -50.36 mm (1.975 in - 1.982 in)2.53-2.680.099-0.105
50.36 mm -50.54 mm (1.982 in - 1.989 in)2.71-2.860.106-0.112
50.54 mm -50.72 mm (1.989 in - 1.996 in)2.89-3.040.113-0.119
50.72 mm -50.90 mm (1.996 in - 2.003 in)3.05-3.200.120-0.125
50.90 mm -51.08 mm (2.003 in - 2.011 in)3.25-3.400.127-0.133
51.08 mm -51.26 mm (2.011 in - 2.018 in)3.43-3.580.135-0.140
51.26 mm -51.44 mm (2.018 in - 2.025 in)3.61-3.760.142-0.148
51.44 mm -51.62 mm (2.025 in - 2.032 in)3.79-3.940.149-0.155
Automatic Transmission Intermediate and Overdrive Clutch Housing Retainer Ring Specification
Dimension MRetainer Ring Thickness (mm)Retainer Ring Thickness (in)
0.85 mm -0.95 mm (0.033 in - 0.037 in)3.80-3.900.149-0.153
0.95 mm -1.05 mm (0.037 in - 0.041 in)3.70-3.800.145-0.149
1.05 mm -1.15 mm (0.041 in - 0.045 in)3.60-3.700.141-0.145
1.15 mm -1.25 mm (0.045 in - 0.049 in)3.50-3.600.137-0.141
Automatic Transmission Fluid Pump Specifications
Size ClassificationThickness (mm)Thickness (in)
IMPORTANT: Rotor and slide must be chosen from the same size
classification as the oil pump body. Allowable rotor and slide
to fluid pump body end play is as follows:
Specification:
Slide to fluid Pump Body End Play0.030-0.051 mm(0.0012-0.0020 in)
Rotor to fluid Pump Body End Play0.030-0.051 mm(0.0012-0.0020 in)
The fluid pump assembly has a selective rotor and slide components
These components are chosen based on pump body dimensions. Fluid pump
rotor and slide components are available in five size classifications
(1-2-3-4 and 5) with the following tolerances:
Rotor Selection
117.948-17.9610.7066-0.7071
217.961-17.9740.7071-0.7076
317.974-17.9870.7076-0.7081
417.987-18.0000.7081-0.7086
518.000-18.0130.7086-0.7091
Slide Selection
217.991-17.9740.7071-0.7076
Fluid Pump Body Depth
117.978-18.0120.7077-0.7091
217.978-18.0250.7083-0.7096
318.004-18.0380.7088-0.7101
418.017-18.0510.7093-0.7106
518.030-18.0640.7098-0.7111
Automatic Transmission General Specifications
Name5L40
RPO CodesM82
Production LocationStrasbourg - France
Vehicle Platform Engine/Transmission UsageM
Transmission DriveRear Wheel Drive
1st Gear Ratio3.42:1
2nd Gear Ratio2.21:1
3rd Gear Ratio1.60:1
4th Gear Ratio1.00:1
5th Gear Ratio0.75:1
Reverse Ratio3.03:1
Torque Converter Size - Diameter of Torque Converter Turbine245 mm
Pressure TapsLine Pressure
Transmission Fluid TypeDEXRONTM VI
Transmission Fluid Capacity - ApproximateBottom Pan Removal Complete Overhaul: Dry 8.9L (9.4 qt)
Transmission Type: 5Five Forward Gears
Transmission Type: LLongitude Mount
Transmission Type: 40Product Series
Transmission Type: EElectronic Controls
Position QuadrantP-R-N-D-4-3-2
Case MaterialDie Cast Aluminum
Transmission Weight Dry73 kg (161 lb)
Transmission Net Weight80.5 kg (161 lb)
Automatic Transmission Fluid Capacity Specifications
Transmission Fluid Capacity - Complete Overhaul8.9 liters9.4 quarts
Transmission Fluid Capacity - Dry8.5 liters9.0 quarts
Bottom Pan Removal7.0 liters7.4 quarts
Torque Converter (245 mm)2.9 liters3.1 quarts
Torque Converter (258 mm)3.1 liters3.3 quarts
Measurements are approximate.
Automatic Transmission Range Reference
Range|---D432---|NRP
Gear11223345-R-
Engine Braking*NoYes*NoYes*NoYesYesYes-Yes-
Direct Clutch------AA---
Coast ClutchAAAAAAA----
Reverse Clutch---------A-
Forward ClutchAAAAAAAA---
Forward Clutch SpragLDLDLDLDLDLDLD----
Over-Drive Clutch-----A-A---
Intermediate Clutch Sprag----LDLD-----
Intermediate Clutch----AAAA---
Low Clutch SpragLDLD---------
Low and Reverse Clutch-A-------A-
Second Clutch--AAAAAA---
Second Clutch Sprag--LDLD-------
Second Coast Clutch---A-------
A=Applied
LD=Locked in Drive
* Engine Braking is electronically controlled by
the TCM and is available as calibrated for each
model and application
Automatic Transmission Shift Solenoid Valve State and Gear Ratio
Gear Range1-2/3-4 Shift Solenoid2-3 Shift Solenoid4-5 Shift SolenoidGear Ratio
Park - Reverse - NeutralOFFONOFF3.16:1
FirstOFFONOFF3.45:1
SecondONONOFF2.21:1
ThirdONOFFOFF1.59:1
FourthOFFOFFON1.00:1
FifthOFFOFFOFF0.76:1
All shift solenoids are normally-closed.
The 4-5 shift solenoid also enables engine braking.
Automatic Transmission Shift Speed
TPS %Output Speed (MPH)
1-2 Shift128
2510
5017
2-3 Shift1216
2519
5030
3-4 Shift1228
2530
5049
4-5 Shift1241
2550
50106
2-1 Shift125
255
505
3-2 Shift1213
2513
5013
4-3 Shift1223
2523
5023
5-4 Shift1231
2531
5040
3rd Gear TCC Apply1224
2545
4th Gear TCC Apply1226
2530
5th Gear TCC Apply1231
2575
Automatic Transmission Internal Mode Switch Logic
Gear Selector PositionABCP
ParkLOWHIHILOW
Park/ReverseLOWHIHIHI
ReverseLOWLOWHIHI
Reverse/NeutralHILOWHIHI
NeutralHILOWHILOW
Neutral/Drive 5HILOWLOWLOW
Drive 5HILOWLOWHI
Drive 5/Drive 4LOWLOWLOWHI
Drive 4LOWLOWLOWLOW
Drive 4/Drive 3LOWHILOWLOW
Drive 3LOWHILOWHI
Drive 3/Drive 2HIHILOWHI
Drive 2HIHILOWLOW
OpenHIHIHIHI
InvalidHIHIHILOW
HI = Ignition voltage
LOW = 0 voltage
Automatic Transmission Line Pressure
Pressure Control Solenoid Valve AmperageImperialMetric
0.1173-197 psi1 194-1 355 kPa
0.3162-188 psi1 118-1 296 kPa
0.5145-169 psi1 002-1 166 kPa
0.7117-140 psi804-966 kPa
0.895-119 psi654-819 kPa
0.963-89 psi453-611 kPa
1.142-64 psi288-440 kPa
Engine at 1300 RPM
Automatic Transmission Component Resistance
ComponentCircuit NumberWire Color*Inline Connector PinResistance @ 20°C (68°F)Resistance @ 70°C (158°F)Resistance to Ground - Transmission Case
1-2 Shift Solenoid Valve1525WH1715.0-17.0 ohm17.9-20.3 ohmGreater than 50K ohm
1222BK14
2-3 Shift Solenoid Valve1525WH1715.0-17.0 ohm17.9-20.3 ohmGreater than 50K ohm
1223BU9
4-5 Shift Solenoid Valve1525WH1715.0-17.0 ohm17.9-20.3 ohmGreater than 50K ohm
898GY5
Pressure Control Solenoid Valve1228GN133.5-4.6 ohm4.2-5.5 ohmGreater than 50K ohm
1229WH8
TCC PWM Solenoid Valve1525WH1710.0-11.5 ohm11.8-13.6 ohmGreater than 50K ohm
418YE20
Input Speed Sensor1230YE18325-485 ohm385-575 ohmGreater than 50K ohm
1231WH15
Output Speed Sensor400OG1325-485 ohm385-575 ohmGreater than 50K ohm
401WH3
TFT Sensor1227RD10Refer to Transmission Fluid Temperature Sensor
""2762WH6Specifications .
* All wire colors are internal to the transmission.
Update: Added general specifications
Reactions: agent008
Anyone think this is going to be helpful information? Hopefully is it easy enough to understand.
I want to know if I should continue to add to it.
both. it is the same spec for both.
I have noted if there is a difference between the 2 vehicles.
Reactions: agent008
slivergxp&.wicked coupe,dirtbike,4wheeler twin turbo ford
yes it will be helpfull, especialy if they make it a permanate thread like the ones above. thanks kev !!
and dont forget the torque for the loose nut behind the wheel. o_O
Discussion Starter · #8 ·
I have compiled every torque spec for the car and also fluid capacities and all kinds of other things as well. I just have to get the last bunch of them formatted into tables for the forum I wrote a program that does the majority of the conversion. I am printing to PDF and then converting from PDF to CSV and then from CSV to what the forum uses. The conversion from PDF to CSV is the one that gets boogered up and I have to go in and manually correct it. It's not a huge deal as most of the stuff is correct it just takes time to read over all of it to make the corrections needed.
Excel can export to csv...
I have found that I can cut&paste from Excel into the forum. I do this in the 'coupe photo book' thread
Discussion Starter · #11 ·
I still have to convert it from PDF and that's where it's not perfect. PDF tables are screwy and they can be done several different ways. The GM shop manual was not written by a single person so the tables are not all made identically.
Discussion Starter · #13 ·
I will have a table for those I am going to add a bunch more later tonight.
Reactions: Super Serg
Discussion Starter · #14 ·
someone did say something about transmission specifications right?
About the Wheel alignment, are the specs you posted here suitable for a standard alignment equipment? Or do we need to use the special tool for setting the rear.
· Administrator
The only adjustment that requires the special tool is the rear caster. The recommendation is that if the tool is not available the caster link should not be touched as there is no way to determine caster without the tool.
2009 , Solstice base 5 speed Red
Thank you for this great resource . I just purchased/received my factory/HELM service books , but this is much nicer than flipping thru 3 volumes and untold pages to find this info . It is going to be vary handy.
yes kg has done a great job hear. does any body know if the gxp and the base have the same auto trans? or might the gxp have the 5L50E trans witch has more clutches to handle more power...
1 - 20 of 23 Posts
