So i just noticed DDM signature:
2.4L - Stage 3 Supercharged - 305whp - 93 octane
2.4L - Rotrex Supercharged - 340whp - 93 octane
2.4L - Custom Turbo - 304whp - 93 octane
2.0L - 2871 Hybrid turbo - 371whp - 93 octane
And I was surprised to see the WHP differences between the Rotrex SC and the Stage 3 MP62. Is there a simple answer for the 35whp difference?
Due to the price differences and complexity involved, I keep waffling between supercharging and a V8.
The biggest difference is the power delivery of the different superchargers. The Rotrex is a centrifugal supercharger, which means it builds boost with RPM and peak power comes closer to redline. The MP62 based superchargers basically hit peak boost as soon as you open the throttle at any RPM and maintain that boost throughout the rev range. That makes it sound like the MP62 superchargers are going to be better all of the time, however that is not the case. The Rotrex units make more power than the MP62 at the same pressure and there are different versions available that can make lots of power with the same brackets and charge tubes.
All of that being said, from our experience, this is how you make the choice -
Automatic or manual car and you like to rev the engine to 7000RPM all the time = Rotrex
Manual car and like that strong bottom end and mid range = MP62 kit
I really like the Rotrex since it is a high ROM screamer and is also silky smooth, but then I am used to revving the engine out to redline all the time coming from the small displacement 4 cylinders in the Miata.
I am actually finishing up another install right now that is our install for the instructions, I can post some more pics up when I am done also. The MP62 new prototype outlet manifold should be here in a couple weeks and if that validates out well then we will start back with the MP62 kits also.
Hope that helps and doesn't just make it more confusing
Dave
