battery
8559 Views 556 Replies 21 Participants Last post by  Old School
So I started my sol and it seemed like it wasn't turning over as fast as it should so I test the battery and it's at 12.05 volts. Should be 12.6 ish volts. Put my load tester on it and the battery is bad. I have to remove the passenger side front fender to get to the battery. What idiot at GM thought that was a good idea. If I didn't have the knowledge and tools to replace it myself I'd have to pay a shop to replace it. The obvious place for the battery is in the trunk and I'm going to relocate it there at some point. Arrg :mad:
Reactions: 2
461 - 480 of 557 Posts
Passenger side would be fairly easy
Reactions: 1
It's not practical no matter how you go about it but it sure would look good
Reactions: 1
Kenna just got up and came looking for me. I quietly got out of bed earlier and sat in my recliner. She sure looks good in my t-shirt. I feel like the luckiest man in the world. Today's plan is to get the new ECM in my car. Can't wait to hear it run 😁
Reactions: 2
@agent008 how long did you know your wife before you asked her to marry you.
Reactions: 1
It's none of my business, I'm just being nosey🙄
  • Haha
Reactions: 1
Just got off the phone with Tommy's dad, Tom sr. He went in yesterday to get a couple stents in his heart but once they got him under the angiogram they discovered that the blockage's were to bad so he has to have a triple bypass. He's in the ICU until his surgery tomorrow. He's only 48 years old!! The American high fat, high salt and high carb diet is taking people down in record numbers. Diabetes is at epidemic levels as is heart disease too.
  • Wow
Reactions: 3
Kenna, bless her heart got the ECM installed. She knows what tools are what, all I had to do was tell her which drawer to look in. Everything is installed and I still have a no start. The battery was disconnected until the ECM and TCM were plugged in to make sure it couldn't arc or fry something and then she reattached the battery
So I have run out of things I can check and patience so I'm having it towed to the shop next Wednesday to have it diagnosed. There's a few things that could possibly be wrong. The key may have lost it's handshake with the ignition, bad park/neutral switch, bad ignition switch. The alarm isn't active according to the dash light. The BCM could have a fault but I don't think so because all the car functions it controls are working. There could be a problem in the fuse box or the wiring. I've tested all the relays and fuses, I pulled each fuse and tested for continuity because I once had a fuse that wasn't burnt looking but was bad. I've run out of things to check. I don't mind having replaced ECM because now I have a spare in case I ever need it. It frustrating not knowing what's wrong but I'm sure the shop will figure it out and hopefully it's something I can fix myself.
See less See more
  • Sad
Reactions: 3
Did you scan it for codes? What about the check engine light, still flickering? And the padlock light, how is it behaving?
I know you are now limited in what you can do for a couple months but if you have a way of checking these things there might be an answer as to what else needs fixing.
No codes without starting the car, CEL is still flickering and the alarm light turns off. I'm done messing with it. I thought for sure it was the ECM but no luck there. I'm thinking it's something in the fuse box or the key lost it's programming. I did a key reset procedure which should restore the keys handshake but I have no way of knowing if it worked or not. It may have fried something in the under hood fuse box when I hooked up the battery charger to the two posts on the side of the fuse box. I really can't do much troubleshooting without bending over and that hurts to much. I had a hard time getting out of the the car when I did the key relearn. Kenna had to kind of get under my arm and lift while I pushed and pulled but she's tiny and wasn't much help 😂 I appreciate your wanting to help but I'm going to let the shop figure it out. At least let them diagnose the problem and I can probably fix whatever is wrong. I can't drive it for at least a couple of weeks anyway.
Reactions: 1
I'm going to lay down for a while, even sitting up makes my chest hurt. My recommendation, don't have open heart surgery because it hurts 🤕
  • Wow
Reactions: 1
We never married, I sometimes joke that we're still dating and the dating phase is the best phase of s relationship 😁
Our relationship became ever more serious little by little. Before we decided to meet, we talked online (presented to each other virtually by a friend we had in common) for about 3 months. Both working hard and late nights and would chat on MSN while doing late night office work. We first had the opportunity to know each other's personality by talking to each other, before we had a chance to like each other physically. After a few months talking we decided to meet in person and at first it seemed we didn't click so mutual interest kinda cooled down. Until new years eve, when I sent a text to my whole contact list, but the lines were congested and the phone kept reporting "send failed" and I kept resending. She told me later she received more than 20 texts from me with the same new years message :ROFLMAO: after the 10th text or so she decided to reply with something funny. We started talking again and when Carnival came she invited me to a party at a friend's house. (There's no big carnival here down south like Rio, it's more of a holiday and parties). We started seeing each other again and as time went on I invited her to travel with me to the beach. There I took her to dinner at a fancy place and asked her to be my GF. Then slowly by slowly I started spending more and more nights at her place. When we were together for about a year I bought a house she told me she liked but I didn't tell her. After a couple months I thought it was time and I surprised her with the keys. But we only moved in together the next year. So you can say we took it little by little and we moved in together (which is what I consider when we "married") after more than 2 years... By then I was spending more nights at her place than at my parents '... 😁
See less See more
Reactions: 1
That's a great story!! I'm not sure I'll marry again. You can be in a committed relationship without making it legally binding which complicates everything if you decide to split up. It sounds like you're happy with the way things are now. Marriage is great if it's the right woman but I found out with my ex wife it can be hell too.
Reactions: 2
I fully understand you Rich, but I just keep thinking that your ECM is still not healthy, or power going into it is not good.
We never had a wedding because every time we calculate the cost we both prefer to travel somewhere. She is the first one to convert the wedding cost in terms of "this can pay X trips"... Costs less than the wedding and we enjoy more 😁
Reactions: 1
Before I had the surgery I checked to make sure my grounds are all good, I have continues 12 volts to the starter so I don't thik it's a power problem, I'm pretty sure something got fried
Reactions: 1
Whatever works for the two of you is great. I hope you have many happy years of dating. :giggle:
Reactions: 1
It's a good course of action. Take it to a shop to diagnose and fix it while you focus on fixing your own body.
Do you mean again in the future? From what you tell us , according to Kenna you are currently married. ;)
Actually enjoy the moment, it may last a long time .
Reactions: 3
Her and her friends are probably already planning the wedding in secret 🤫 she's reading as I type this and she just told me I better marry her or something bad may happen to me involving a dull knife and little Ricky 😱🤣
  • Haha
Reactions: 3
We might as well be married, we already have a daily routine. When she wakes up she makes a pot of coffee and we lay in bed drinking it and talking. We never run out of things to talk about. She starts working at 8:00 and I usually move to my recliner and read a book. Around 10:00 we go for a walk which leaves me exhausted. Around noon she makes us lunch. And so on. We watch TV in the evening and then go to bed. It's a comfortable routine 🤗 I had forgotten how nice it is having a woman in my life.
Reactions: 2
