1 - 20 of 60 Posts
Hey all fellow Solstice GXP and SKY RL owners with the LNF engine!
I would like to start keeping track of some boost information and see if I can correlate DIC boost levels with atmospheric conditions.
To get to that, I need to acquire data from as many of us that are willing to participate. Here is what I would propose:
- We use a standard procedure, simple in nature, to note the maximum DIC boost level.
- Simply run the procedure, note the local date and time, and the nearest airport.
Post the information here in the following format:
Boost level sustained:
Peak boost noted if different than the sustained level:
Date and time:
Nearest airport: (you can also note the city and state, or find nearest ASOS/AWOS via AirNav)
Performance Modifications: (stock, exhaust/intake, stage kit or tune, etc.)
It is that simple. I can calculate the rest from there. I plan on trying to plot the boost pressure and density altitude to see if I can tell what is normal and what different modifications mean.
The procedure:
-Make sure your car is warm. DIC coolant temperature should be >185ºF
-Set your DIC to monitor boost. Be sure to wait until the display is active (displaying the PSI, not "BOOST" when the gage is initiating)
-Start the procedure in 3rd gear at 30-35 MPH (approximately 2000-2500 RPM)
-Go to Wide Open Throttle (WOT)
-Note the sustained and peak values you see on your DIC. Accelerate to as high a speed as you are comfortable.
-watch out for deer, pedestrians, other cars and curves. Maintain control of your car at all times, and obey traffic laws where applicable. :)
-Note the date and time.
Keep in mind that you may see a traction light, so you may want to do this in competitive mode to avoid this happening. If the traction control becomes active, you will lose your boost gage to the superceding traction control message.
For example, on the way in on the morning of 2/17/09:
Boost level sustained: 22
Peak boost level: same (22PSI, solid)
Date and Time: 2009.02.17 06:53 EST
Nearest Airport: Howell or Pontiac (KOZW or KPTK, Milford Proving Ground is 1/2 way between)
Performance Modifications: GM PUpgrade Kit, 6 shortening wastegate turns from stock, stock intake/exhaust
From that, we can determine the weather conditions and calculate the density altitude is -1456' for this run.
I am especially interested in stock vehicles. I think a typical LNF car is not going to be too far away from this:
-2000' (cold day below freezing) 14-15 PSI
-1000' (15-16)
0' (16-17)
+1000' (17~18)
+2000' 19 PSI (close to SAE J1349 standard)
+4000' 20 PSI
+6000' 20~21 PSI
Boost level sustained: 19 psi
Peak boost noted if different than the sustained level: 20
Date and time: 2/19/2009 3:30 pm
Nearest airport: MKE (Milwaukee, WI)
Performance Modifications: GM PUpgrade Kit, Waste gate 4 turns. No other mods
My Car
08 Redline 5-speed manual
Boost level sustained: 21 psi
Peak boost noted if different than the sustained level: 23 psi
Date and time: 2/20/2009 12:30 P.M. MST
Nearest airport: Fort Collins/Loveland CO regional
Performance Modifications: GM PUpgrade Kit, Waste gate 2 turns. No other mods
DIC showed outside temp as 50 degrees F.
My Wife's Car
Boost level sustained: 17 psi
Peak boost noted if different than the sustained level: 19 psi
Date and time: 2/20/2009 12:55 P.M. MST
Performance Modifications: No mods
An interesting thing I noticed with her car. Starting out, it peaked at the 19, then dropped to 16, then continuously gained steadily going up in the rpm till it just hit 18 right before redline. So I called it 17.
With my car; it would peak at 23, with flickers of 24, then drop to 22, then continuous steady drop going up in the rpm till it just hit 19-20 right before redline. So I called it 21.
Do you think this is because the GM tune is adding so much torque lower in the power band that you get more of a "launch" when going WOT in 3rd from 2500 rpm? And therefore it doesn't have to demand as much boost later in the rpm range to achieve max A/F ratio? Or do you think this is the difference between the stock version having the "torque limitation" engaged, resulting in reduced boost at the beginning of the launch, but allowing it to command a little more as torque drops going up in RPM. I am tending to lean this way, because of how "flat" the torque curve is on the stock tune.
I had never tried the load test in 3rd at 35 mph before today. So I had never noticed this difference in the two cars. Both cars seem to react about the same way when doing a load test in 4th at 60 mph. They will both peak then drop 1-2 psi, then hold steady all the way to 100 mph, without the noticeable change in boost pressure, either down or up. (I bet if I had balls enough to hold either one to 130 mph in 4th today, then I would see the boost drop off. But I save that kind of testing for more law enforcement scarce areas. LOL)
Discussion Starter · #5 ·
Info so far:
Typhoon:
METAR KMKE 192052Z 30017G24KT 10SM FEW031 M06/M16 A3001 RMK AO2 SLP175 T10611161 55003
METAR KMKE 192152Z 28013G20KT 10SM FEW031 M06/M16 A3001 RMK AO2 SLP175 T10561161
Elevation: 723 ft.
Density Altitude -1780.6 ft
Absolute Pressure (station pressure) 29.235 in Hg (14.35 PSI)
Relative Density (ISA) 105.31%
Actual Density (kg/m^3) 1.2901
Relative Humidity Relative Humidity = 45%
19PSI (DIC) = 33.4 PSI abs / 2.24 bar
20 PSI (DIC) = 34.35 PSI abs / 2.37 bar
GS Stage 1
Elevation: 5016 ft.
METAR KFNL 201935Z AUTO 29037G45KT 10SM CLR 12/M16 A2985 RMK AO1
Density Altitude 5931.6 ft
Absolute Pressure (station pressure) 24.82 in Hg (12.2 PSI)
Relative Density (ISA) 83.76%
Actual Density (kg/m^3) 1.0260
Relative Humidity Relative Humidity = 12%
21 PSI (DIC) = 33.2 / 2.29 bar
23 PSI (DIC) = 35.2 / 2.43 bar
GS Stage 1 Wife
METAR KFNL 201955Z AUTO 28031G45KT 10SM CLR 12/M14 A2984 RMK AO1
Density Altitude 5947.7 ft
Absolute Pressure (station pressure) 24.811 in Hg (12.2 PSI)
Relative Density (ISA) 83.72%
Actual Density (kg/m^3) 1.0255
Relative Humidity Relative Humidity = 15%
29.2 2.013269044
31.2 2.151164184
17 PSI (DIC) = 29.2 PSI abs / 2.01 bar
19 PSI (DIC) = 31.2 PSI abs / 2.15 bar
My run was
Density Altitude -1456 ft
Absolute Pressure (station pressure) 29.088 in Hg
Relative Density (ISA) 104.33%
Actual Density (kg/m^3) 1.2780
Relative Humidity Relative Humidity = 79%
22PSI(DIC) = 36.29 PSI abs / 2.5 bar
Interesting stuff, Flash.
Assuming I understand this correctly: So even with your WG set as tight as it is, you still have a lot of room before the 3 bar limit. But of course there is still that pesky max manifold pressure limit and max turbo RPM limit imposed by the ECM.:lol: I sent you a PM also.
Discussion Starter · #7 ·
As always, the overboost code is the difference between COMMANDED boost and ACTUAL boost. You are right, though, there is always the turbine speed limit, and the detonation map limit, which dials back if you approach conditions favorable to detonation. Not that I am anywhere near that level yet.
This morning, it was f'ing cold:
Peak boost level: same (21PSI, intermittent)
Date and Time: 2009.02.24 07:15 EST
Density Altitude -3110.3 ft
Absolute Pressure (station pressure) 29.35 in Hg
Relative Density (ISA) 109.42%
Actual Density (kg/m^3) 1.3404
Relative Humidity Relative Humidity = 85%
19 PSI (DIC) = 33.4 PSI abs / 2.30 bar
21 PSI (DIC) = 35.4 PSI abs / 2.44 bar
Boost level sustained: 23 psi
Date and time: 2/24/2009 5:3450 am
Nearest airport: Centenial Denver
Performance Modifications: GM PUpgrade Kit, Solo high flow cat, Magnaflow, Dejon charge tubes, CAI, intercooler.
This morning's results
Boost level sustained: through 1st and 2nd gear 18 pounds. 3rd and 4th gear 23 psi
Date and time: 2/25/2009 5:45 am
Discussion Starter · #10 ·
Rob the Elder:
Nearest airport: Centenial Denver (5885 ft)
Density Altitude 5844.6 ft
Absolute Pressure (station pressure) 24.14 in Hg
Relative Density (ISA) 83.98%
Actual Density (kg/m^3) 1.0287
Relative Humidity Relative Humidity = 70%
23 PSI DIC = 34.86 PSI absolute / 2.4 bar
Density Altitude 5994.8 ft
Absolute Pressure (station pressure) 24.182 in Hg
Relative Density (ISA) 83.59%
Actual Density (kg/m^3) 1.0240
Relative Humidity Relative Humidity = 38%
23 PSI DIC = 34.88 PSI abs / 2.4 bar
I remember something about boost in 1st/2nd gear, but it slips my mind right now. There is an explanation about why the boost is lower in those gears.
Discussion Starter · #11 ·
It appears that nearly untouched PUpgrade Kit cars have a target boost of about 2.3 bar, and maybe another .1 bar for efficiency upgrades like Rob the Elder's car. If you go extreme on the wastegate and are low enough density altitude to avoid knock, as high as 2.5 bar may be possible.
All absolute pressure, independent of current density altitude.
My checks on stock vehicles supports between 1.9 and 2.05 bar.
Furthermore, I can calculate a preliminary correlation of DIC displayed pressure and density altitude. It seems to work out to be approximately 2500 ft change in density altitude = 1 PSI change in DIC displayed output, the higher the DA, the higher the displayed boost.
In a weird and wacky way, if you have a good feel for your DIC and your car, you can use the boost as an approximation of density altitude, plus or minus about 1200 feet. LOL
On the assumption that the system is trying to boost to the same approximate mass air flow:
DA=7000', DIC displays +2 PSI from standard conditions
DA=4500', DIC displays +1 PSI from standard conditions
Standard (2000' DA)
DA=-500', DIC displays -1 PSI from std conditions
DA=-3000', DIC displays -2 PSI from std conditions
If the absolute pressure for a base car in standard conditions is 15PSI, then the DIC would display as follows:
DA=7000', 17 PSI
DA=4500', 16 PSI
Standard (2000' DA) 15
DA=-500', 14 PSI
DA=-3000', 13 PSI
and a PUpgrade Kit car DIC displayed boost might be something closer to:
DA=7000', 22 PSI
DA=4500', 21 PSI
Standard (2000' DA) 20
DA=-500', 19 PSI
DA=-3000', 18 PSI
And since we start to see turbine overspeed corrections in DA>8000', it appears that this is approaching the limit for the current turbine, or approximately 26 PSI boost over atmospheric.
Peak Boost level: 23
Date and Time: 2009.03.13 13:45 PDT
Nearest Airport: San Francisco International KSFO (altimeter at TOT 30.19 | 43 ' above sea level)
Performance modifications: GMPP Upgrade Kit, 5 turns of wastegate from stock position
Side notes: Since new, the car has only been filled with Chevron with Techron 91 octane
Current mileage 2585
Test conditions: 1/2 mile straight frontage road, no traffic, 64 degrees F, clear and dry. Less than 5 miles south of runway 28 at SFO.
Is this only for people with GMPP upgrade kit??
I have westers tune.
Peak Boost level: 25
Date and Time: March 14th, 2009......1PM PST
Nearest Airport: El Monte Airport (KEMT) Elevation AMSL 90.2 ft / m
Performance modifications: Dejon intake/spring/IC. Westers Race Tune (91 octane), WG shortened to only 4 threads showing.
Side notes: Current mileage 15,200
Discussion Starter · #15 · (Edited)
Not necessarily, Deep. Anyone who has a boosted car - even stockers.
Discussion Starter · #16 · (Edited)
DDD ENGR
METAR KSFO 131956Z 28015KT 10SM FEW014 13/08 A3018 RMK AO2 WSHFT 1938 SLP219 T01280078
METAR KSFO 132056Z 29012KT 10SM FEW014 13/08 A3014
13' Elevation (if your local elevation is different than the nearest airport, please let me know)
Density Altitude -358.1 ft
Absolute Pressure (station pressure) 30.146 in Hg
Relative Density (ISA) 101.05%
Actual Density (kg/m^3) 1.2379
Relative Humidity Relative Humidity = 72%
21 PSI DIC = 35.8 PSI abs / 2.47 bar
23 PSI DIC = 37.8 PSI abs / 2.61 bar
Deep-GXP
METAR KEMT 141947Z VRB06KT 5SM HZ BKN000 OVC015 A3001 [elevation 296']
METAR KEMT 142047Z VRB06KT 5SM HZ BKN015 BKN060 A2998
METAR KFUL 141953Z VRB05KT 9SM OVC025 15/09 A3001 RMK AO2 SLP162 T01500089 [elevation 96']
METAR KBUR 131953Z VRB05KT 10SM CLR 18/07 A3004 RMK AO2 SLP167 T01780067 [elevation 778']
Using 300' as local elevation, info from KFUL (17 NM south of KEMT, which does not have an official METAR with temperature
Density Altitude 416.6 ft
Absolute Pressure (station pressure) 29.686 in Hg
Relative Density (ISA) 98.79%
Actual Density (kg/m^3) 1.2101
Relative Humidity Relative Humidity = 67%
22 PSI DIC = 36.58 PSI abs / 2.52 bar
25 PSI DIC = 39.58 PSI abs / 2.73 bar
Discussion Starter · #17 ·
SAE J1349 conditions are 25ºC, dry air, 99kPa station pressure.
Density Altitude 1946 ft
Absolute Pressure (station pressure) 29.235 in Hg (990 mb, 99kPa)
Relative Density (ISA) 94.43%
Actual Density (kg/m^3) 1.1567
Relative Humidity Relative Humidity = 0%
This morning on my usual route it hit 21 pounds of boost peak in 2nd gear where previously was peaking at 20 pounds. Was a rolling start up the on ramp to E 470, same location as above. Went immediately to 20 pounds as expected then went UP again to 21 pounds through 2nd and 3rd gear under continuous WOT.
Went to 23 pounds in 4th till I gave up.
I expect this is due to atmospheric conditions.
05:45 AM
Flash explained why SLY is seeing better boost between North Wilkesboro and Boone NC.
Knew this might happen but confirmed it on the Junior Johnson Expressway :glol:
Asheville was fun because it was damp and cooler part of the time. I grew up in the town so I know the area and the BRP like the back of my hand.
Did not go to Mt. Mitchell, highest peak E. of the Miss. but can't wait for CO.
Flash did some great work and I think the DDM tune and mods on SLY are in line with Flash's numbers in this thread the difference being the graph in where torque and Hp cross and from 8lbs to 14lbs :D
That is where things get wicked as when 6-8lbs hits the DIC, the jump is almost instant 14lbs then a rabid, not rapid foam at the mouth climb to 21 sustained. The limit is set at 23lbs.
Another member I think will back me up on this, but I am also stupid flow out the back. Another toon tweak and then maybe a dyno :D
DDD ENGR
Thanks Flash's Owner. Much appreciated. For altitude, I was using a Brunton ADC Summit altimeter. Calibrated at time of test using ASOS info from KSFO.
1 - 20 of 60 Posts
