1 - 7 of 7 Posts
2008 Soltice Both low beams suddenly quit working. No modifications or previous problems. I'm looking forward to your replies
DragLine, Thank You
you didn't accidently turn them off by twisting the turn-signal stalk did you ?
if not, then I would guess a fuse. You'll have to check the manual for which fuse...
Thanks for replying. The fuse is #65. I have checked it's ok. I ordered new bulbs from Amazon. Can't
find where to connect VOM. I'll see what happens when the bulbs get here
You can also try re-seating the relays. One of them is for the low beams, and there has been a history of them occasionally getting loose.
It is also possible, although very uncommon, that the relay has failed. Do the high beams work? If so try swapping the relays.
Reactions: Sting Ya
1 - 7 of 7 Posts
