OK so this is the skinny on brake pads.
The main 3 are
Organic
Metallic
Ceramic
There are mixtures or "blends" of the 3 above, so there will be a sharing of the properties. Like semi-metallic which is a blend of organic and Metallic
Ceramic pads are the new type of pad, they have been around since the 1980's so they really aren't new anymore. as is anything that is "new" people will make a false assumption that they are better. This is not always the case.
Organic
quiet, lots of dust, decent grip, wear down fast, easy on the rotors, doesn't transfer heat to other braking components, doesn't handle high temperatures well
Metallic
noisy, medium dust, best grip, medium wear, hard on the rotors, transfers heat to other brake components, works well in high temperatures.
Ceramic
super quiet, lowest dust, grip is variable, best wear, can be either hard or medium wear to the rotors, low transfer of heat to other components, medium temperature handling
Best pads for a performance driver are going t be a metallic based pad. they offer the best balance of grip, wear, and heat handling. This comes at a cost f having to replace the brake rotors more often.
There is a large lack f knowledge surrounding ceramic pads. They can be good and they can also be very bad. All brake pads should be bedded into the rotors when they are replaced. Ceramic pads are the most important to do this with because this is how they are designed to work. Bedding a pad and rotor together is the removal of pad material and the placement of that material onto the rotor surface. the only way to achieve this is through extreme high heat. The recommended way to do it is to get the car up to say 90MPH and stomp on the brakes as hard as possible. slowing the car down to 10MPH, then speeding back up .. you repeat this process 5-7 times and then drive at 30-40 mph for 10 minutes not touching the brakes a single time during that time and let the brakes cool.
The above bed in cannot really be done on the street. If this process is skipped with ceramic pads you will have reduces pad life, loss of grip and excessive rotor wear.
Another issue with ceramic pads is what is called brake jutter, the more common term if a warped rotor. This can happen with any type of pad material but is more common when using ceramic pads. Let me explain what this is.
All rotors have some degree of "wobble" to them. so does the wheel bearing on a car. When mounting a rotor on a car it is of utmost importance that the rotor wobble is 180° out from the wheel bearing wobble. doing this will produce the least amount of run out or total wobble of the brake disk. When there is excessive run out the pad is going to contact the disk with a higher force in different areas of that disk. Because of how Ceramic pads are designed to work and work on the principal of depositing material onto the rotor when there is high heat you actually end up with mounds of material. the rotor ends up having a "wave" to the surface of it. So if using ceramic pads the run out on each disk should be checked. If you have the rotor and wheel bearing set to 180° and there is still excessive run out then you need to turn the rotors. After that has been done and there is still excessive run out the wheel bearing is going to been to be replaced.
Now another bad thing about ceramic pads.. remember that transfer of material because of high heat? well that happens when a driver comes to a stop and doesn't let the vehicle roll slightly after stopping. The brake pads have gotten really hot coming too that stop and where the pads sit against the rotor as they cool they deposit material. This material builds up over time and causes high spots in the disc and brake jutter will happen. This happens less with metallic or organic pads, it can still happen.
Really simple idea here..
If you want good performance brakes you are going to have dust, and they are going to be noisy, This is how it is. it takes friction too stop a car and the byproduct of that friction is noise and dust. The Solstice is a sports car not a luxury car and not an economy car. There are things that you must do when you own a sports car and you drive the car like it is intended to be driven, more frequent oil changes, more frequent brake replacement, washing the dust off the wheels.. the brake noise is probably not so much of a concern because the Solstice is not exactly a quiet car to begin with.
Why do you think that dark colored wheels are more popular?? because people are lazier then they used to be and do not want to have to pull up the stool and a toothbrush to clean the dust out of the chrome wheels. Chrome wheels were the thing back in the day. no one wanted anything other then chrome, back then people didn't mind spending a few hours cleaning their wheels every week. Now.. in the world we live in today.. if it doesn't have a screen on it then most people aren't interested in looking at it for more then 10 minutes.
Keeping that dust off your wheels is going to be expensive, most shops do not check for run out and are not going to bed the brakes properly. using ceramic pads to keep the dust down is going to cost a lot of money over the length of time you own the vehicle. with metallic or organic pads you will not have to replace rotors every time you replace the pads. and in the end you will most likely have to replace the brakes less if you use metallic because you will not be replacing them before they are worn like you may end up having to do with ceramic because of jutter.
so keep that in mind. and if you pay a shop to replace your brakes. Make sure they check the run out, stand there and watch them do it. don't take their word for it.
