1 - 3 of 3 Posts
What type of lube/grease is recommended for the caliper pistons? From my searches this seems a bit of a taboo topic since many people say the most common greases you find in parts stores aren't compatible with brake fluid and will gum it up.
So far i found that castrol red rubber grease is good for rubber + metal contact and is brake fluid compatible, anything else?
What do you want it for? I use assembly fluid for assembly and rubber grease in the caliper boots to exclude dirt and water.
Don't let any normal lubricants in contact with brake rubbers.
1 - 3 of 3 Posts
