1 - 20 of 20 Posts
When my car hits almost 5k rpm my car bogs out and check engine light comes on just until I shift gears.
I was told I need spark plugs, any ideas?
Thanks!
Sent from my iPhone using Autoguide.com Free App
What DTC did you get? Start there.
Check for clogged cat, are you boosting? If so don't push it cuz it might also be detonating.
Sounds like a clogged cat. I know a guy who has one for when you get frustrated 'cause you can't get one through GM!
It through my check engine light on but it went off this morning so i couldn't scan it when I cranked up. I was planning on buying a high flow cat from solo if that's the problem
Did you scan it even though the light wasn't on? Just 'cause the light is off doesn't mean a code isn't stored.
I've read on the forum that you can take out one of the O2 sensors (in front of the cat) to test. Make a helluva lot of sense 'cause if you eliminate the restriction you won't get the hesitation. Noisy, but a quick diagnostic.
Thanks!Sent from my iPhone using Autoguide.com Free App
I had a similar issue and it turned out to be one of my coil packs. My check engine light came on and indicated I had a misfire on cylinder #2. The tech switched the coil pack to #3 cylinder and drove it again. Then the misfire went to cylinder #3. I replaced the coil pack and no more problems. I have read about this problem a couple of times so it is worth looking in to. Please let us know how things turn out.:lurk:
http://www.solsticeforum.com/forum/f59/need-some-spark-plug-help-please-73383/
Discussion Starter #13
I have heard this could be an issue too. Hopefully I can check it out tomorrow and fix whatever it is.
Can any of the coil packs be changed around and swapped out with each other? I might try this tomorrow and checking my cat converter too.
Thanks!
I hope this is worked out quickly for you. Please PM me if you take it to a dealership to have it serviced. Keep us posted.
Matt,
GM Customer Assistance
Discussion Starter #15
PROBLEM FIXED (permanently I hope), I checked my spark plugs and 1 wasn't screwed in enough and I had a sensor loose, I think it was an O2 sensor.
I'll update if problem isn't fixed but I took a test drive and all is well as of now!
Discussion Starter #17
UPDATE #1 - Still isn't fixed.
Going to check the ignition coil pack, o2 sensors and cat converter.
Hopefully 1 of these 3 is the problem and easy fix.
Discussion Starter #18
UPDATE 2 (and the final update) :)
the problem was that my ignition coil ground wire that connects to the engine slowly began melting and after today I connected it back and the problem is gone!!!
lol - We'll hang out and just make sure the "final" update is the "final" update. : )
Discussion Starter #20
So far so good, been driving it hard and everything is in working order. I'm glad it was a free fix, I could have easily spent a lot of money on parts that wouldn't have worked.
1 - 20 of 20 Posts
