Hi guys, Ive tried researching as much as i can and I was really hoping that changing my thermostat would fix it, and im still hoping that now its just an air bubble in my coolant, (im hoping its not water pump) ...anyway here is what is going on... One drive last week after i got home, i noticed my fan was on after turning the car off (the fan that cools the engine) , ive never noticed it before, but I didnt think anything of it. The next drive, about 10 minutes down the road my coolant temp light came on, I switched over to view temp and it was 260s ...i pulled off and shut it down for a while...started it back up and proceeded home (less than 10 miles away) and would pull off everytime it got too hot (maybe 2 or 3 more times) ...so when I got home I let it cool off for a while (6 hours) ..I went out to check the coolant and it was very low (could this be because it got so hot it boiled/evaporated?) ...so I filled it up to where it should be and the next day started it up and drove it around and it started to get to hot again, so I shut it down. I then changed my thermostat yesterday and used DDMs burping procedure to refill the coolant (I may have made a few mistakes, after holding the reservoir tank up and puring coolant in until it came out of the nipple (and it was burping at first), I then lowered it and filled it to the proper level and put the cap on and started the car, Im not sure if I was supposed to leave the cap off when I first started the car, and im not sure if I was supposed to already fill it all the way up or waited for it to idle and filled it up) ...could these mistakes have kept an air pocket in? Also, I heard one time may not be enough, so if I should try the procedure again, can someone give me a photo or diagram showing how I drain the coolant? and can I do this without lifting, and can I fit a drain pan under the car and where do I put the pan?
...sorry for the novel ... also, I have read and have the service manual as to where I may need to clamp off the turbo line at the beginning of idling after a new coolant refill because if I dont the coolant may never reach the heater core (is this accurate, and could this be why I still do not have any hot air blowing)
...I also saw on here that there is a method of squeezing a radiator hose and if it sloshes to keep squeezing and this may get air out, can someone confirm this and tell me which hose to squeeze and how hard to squeeze it?
...I have a picture of the thermostat I took out (my old one) can someone confirm that it looks bad (so I dont feel like I changed it for no reason)
...I also have a picture of some of the lines that I touched after warming the car up (because I read that one should be hot and one should be warm) so I drew a red line on the one that was the hottest, a yellow line on the one that was warm, and a green line on one that was cold ...just to make sure that they are how they should be...
...thank you guys for looking, I honestly dont know very much at all about cars, and this forum has helped me a ton!
