1 - 6 of 6 Posts
My 2007 GXP (86,000 MILES) has started throwing engine codes at me (P-0299 and now P-0420). Oddly enough it went into limp mode without throwing a code the day before the P-0299 popped up and then started up this AM with a P-0420. The Pontiac shop recently changed out the High Pressure fuel pump and I was thinking that they may have not properly attached some of the turbo hoses, but now with the P-0420 code I'm wondering if it may be the CAT. I've been running a High Flow Solo CAT since the first 5k miles, so do y'all think that it could possibly need replacement after 80k miles? Of course I have my OEM CAT, but I really liked the sound and low end torque the SOLO gave me.
It sounds highly likely to me. Give Solo a call and see what their experience has been with normal lifespan of their cats.:thumbs:
Get a sniffer test to find out for sure. They last a fairly long time, normally, but it is hard to predict, so you'd need to check it out. If it is really clogged up you'd know it!
If you don't have an oil catch can, the cat will last 1/2 of the time that it was designed to last.
What's a "sniffer test"?
1 - 6 of 6 Posts
