Hey guys, I recently had a 6 hour road
trip where I filled up at different gas stations as normal. I was wondering if bad gas could cause multiple random misfire codes (300s)? What happens is, I can start my car and it will be completely fine, I will take off and it could be a mile down the road or 15 (completely random) and the car will lose power, check engine light will blink and the car will idle very rough. I pull over, turn the car off, turn it back on, and it's completely fine...I just realized yesterday, when it happened, I just put it in neutral and was about
To pull over and the light stopped blinking and I put
It back in gear and it was completely fine (did not need to turn car
Off) ...the first time it happened it threw codes 626 and 264 (along with the misfire codes) ...it has not thrown those two since the first time (I did have to change a headlight, not sure if that was related), I believe one is a high volt
Code and one is a low voltage code, eitherway, this has not happened again, but the misfires codes happen about once a trip...any ideas?
