so after work I filled my car up for the second time... started it drove home fine about a 4min ride. parked it in the drive way came out tried to start it twice and nothing... then check engine light came on.. let it sit a minute then it started up. I read in my owners manual that the light will come on if you don't tighten the gas cap tight enough (emissions stuff?).. so I tightened it up and it's start 2 other times fine haven't drove it sense.
is this a common thing to happen?
why would it have not turned over twice?
when will the gas light turn back off if nothing is wrong?
i'm a new solstice owner pls help i'm worried.
thanks.
thanks.
