1 - 3 of 3 Posts
I posted this problem some time ago but I am still plagued with this minor but annoying issue. Every once and awhile while driving I will get 3 or 4 chimes like when the door is ajar or the key is still in the ignition. The car runs fine, no door ajar etc, but the reasons for the chimes remain a mystery. It was suggested that I may have left the turn signals on too long but this is not the case. This is one of those situations where it happens infrequently and certainly would never happen if I was paying a mechanic to diagnose the problem.
Any thoughts, Don
i had an older honda where the door switch was acting up.every so often when making a lefthand corner the dome light would come on like the door was ajar.i probably should have sourced another switch but instead i superglued a penny to the door itself where the switch hits the door.while im not sure you want to do this everything worked as intended for years.maybe look at your door switches if it happens upon cornering?
1 - 3 of 3 Posts
