1 - 20 of 21 Posts
Went out for a nice cruise since the rain stopped and sun was out. Car is driving fine until I come to a stop sign. I take off as usual, nice and easy going through the gears(30 mph speed limit) and I hear this clicking/clankiing noise coming from the trans/rear. Made it home and jacked it up. Lots of backlash between the wheels and driveshaft. Is this normal?
Went ahead and changed the rear diff fluid just for drill. Car only has 16K miles on it and was original. Put the car down and backed out of the driveway. Nice and quiet. Pulled off and still nice and quiet. Went on the interstate for 4 miles to make a loop. When I came to a stop, it was back and louder. This time you can feel it in the shifter. Sure sounds like it is coming from the rear end. Made it back home and pulled it into the garage and put it up in the air(ramps on front and jack stands in the rear) Fired it up and it was quiet at first but if you are in 4th gear at 1000 and give some gas, you can hear the noise but I can't figure out if its the trans or rear.
Before I start taking off the shields, anybody have a clue what this could be? Almost sounds like the driveshaft is hitting something but it was too hot under there to see anything.
Any help would be greatly appreciated.
Rob
I can't tell how loud yours might be, so could be something different, but many of us over the years have complained about the "dreaded drive-line clunk". Usually taking off from a stop, when shifting into 1st and 2nd (or back down).
Dealer's response to those who complained was "it's normal". No-one that I know of has had a failure from this, so we all just live with it. If you search the fora, you will find much about this. The only 'cure' seems to be taking apart the rear diff and re-shimming the internals - not for the faint hearted.
I doubt I have that as this just started out of the blue today. It isn't a one and done sound. It keeps going. I thought it might have been the clutch as when I first heard it, it would go away with the clutch pushed in. But now it'll do it with the clutch in.
A failing CV joint will click under load, but that doesn't seem to be when you are hearing it, although it would explain the backlash you feel.
Always a possibility but I see no grease or split boots. The gear lash I hear when moving the tire is in the rear end.
I took off the transmission cover and everything is nice and dry. I can only see back to where the torque arm is bolted to the trans. What I find odd is there isn't a trans mount. I've never seen a car without one. Doesn't even look like there is a spot for one. Very strange...
I'll pull the other pans tomorrow after work and see what I can find out, if anything.
Do you have chrome wheels? Something quick and easy to check, make sure none of the chrome is peeling off on the backside and "clicking" on the brake caliper. I've seen this so many times in the dealership world, it's not even funny.... Otherwise I'll leave the recommendations to the others....
The early cars are famous for a driveline "clunk" that was solved by installing the strut connecting the transmission to the drive axle, eliminating the transmission mount and the front axle mount. Engine, transmission, and drive axle are essentially one solid unit.
You can have a CV joint fail for reasons other than splitting a boot and losing lube and/or gaining contamination. There are also two joints in the propeller shaft.
Yes, I'll have to check that also. Thanks
How about that rubber driveshaft coupling? If I recall. the bolts are known to loosen up. Or maybe it's dry rotted.
Once I pull the rest of the covers off, I'll be able to check that.
There just seems to be a lot of play between the rear and the driveshaft, at least to me.
Discussion Starter #11
UPDATE:
I think it's something in the clutch. I took the car out and it was banging/knocking like a hammer. Either under load or coasting. Pop it in neutral and the sound is gone. Put it back in gear and it's there. Then all of sudden the sound was gone and it was as quiet as it was right before it happened. Parked it for a couple hours and it was back but nowhere near as loud. Got on it and took it up to 6500 in all gears and it was quiet as a mouse again. Haven't taken it back out again to see if it's there or not. Just strange that it started doing it out of nowhere and goes away and comes back.
So does this sound like anything happen to anybody?
sounds like my ac compressor on my 06. it comes ad go,s. 1 thing to remember nutral dosent disengauge the clutch or take it out of play.pushing in the clutch peddel does disengauge the clutch and stop it when sitting still in gear. if your in nutral and it comes ang go.s it could be the clutch or the trans.if it's in gear,stoped and the clutch is pushed in and it's making noise than I wood say yup probably clutch...or...thrust bearing in the engine...but it sure sounds a lot ,like my ac compressor that is aggravating. you may want to change trans gear lube and have a good look at the old fluid to see if it's got the look of death in it...or a disco ball....
Well...if I had to guess, it sounds like you are missing a tooth/spline in your diff.... But, it could be trans too. Do you have access to a hoist? If so, lift the wheels off the ground, put it in gear and then raise it so you can hear/see where it's coming from at this point... Definitely something rotating with speed. It could be anything from bearings in the rear wheels all the way to the front of the trans. But, since it doesn't get louder with speed and stays consistent with speed, I'm willing to guess you chipped a tooth.
Discussion Starter #19
When I changed the original fluid, there was nothing solid on the drain plug. Just fine particles like I'd expect.
When I had it up in the air a couple weeks ago, it wouldn't make the noise. I'll try to get it back up and do it again.
Did you ever solve the issue?
That sounds like the frequency of the noise MULTIPLIES when you shift gears and incrementally increases with engine speed. Immediately after shifting, the sound gets much more frequent but you haven't sped up yet as you JUST changed gears. I would think this indicates an internal issue in the transmission.
1 - 20 of 21 Posts
