1 - 2 of 2 Posts
Hello from spain, we are trying to remove the screw on the crankshaft pulley and is costing us a lot, is removed in the same way as a normal screw, right? We are trying to remove the reverse of clockwise, is it ok? we haven,t the tool to bloked the crank :(
Thank you very much:thumbs:
Bolt should come off turning counter clockwise. Manual says you're not supposed to re use the bolt, so it probably has thread locker on it. Try an impact wrench.
1 - 2 of 2 Posts
