1 - 20 of 116 Posts
Thought I would start this thread as an option for those who have exhaust that another vendors product might not fit.
Check it out on DDM Works web site.
How are the bolts that attach to the existing plate (2 have to be drill) go on?.
Do you have to take the carpet off from the trunk to do the install and secure the bolts?.
No, the frame rail that runs from right to left, you drill up from the bottom. You then place the bolt through the Pro Beam, through the frame beam, then you use a washer and nut on the top of the frame beam. It looks like a very secure unit, much stiffer than the kappasphere.
Do to the nature of suspension stiffening, I would expect you will fell it more in the front than the back, it has always amazed me that a bigger sway bar on the back changes the way the front reacts in cornering and vice versa. Initial reviews have said that people are noticing less nose dive with the bar in place.
I already have the GMPP suspension and couldn't feel anything as far as a stiffer ride. It's like goat said, the difference is in the cornering. It goes into and comes out of the corners without diving nearly as much. It's a Good Thing ™.
Vendor
Here is a link to the instructions:
http://www.ddmworks.com/instructions/DDMWorks_Pro-Beam_Installation.pdf
As for the difference with the Pro-beam on, I think everyone's comments about it about sums it up. The car takes a set a lot faster going into a turn, making the car feel lighter on its feet and a lot more fun :)
Vendor
We had 6 customers from the first batch that had Magnaflow exhausts on their cars, I do not know the exact sizes of their systems though. A car here in the shop has a Magnaflow 2.5" and it fits without a problem. Also if for some reason it does not fit, you are always welcome to return the brace, no questions asked :)
Magnaflow 3 inch exhaust
have you guys heard of any customers who installed your beam with a magnaflow 3'' exhaust? Just trying to make sure of my clearances. thanks
I have the Magnaflow 3 inch exhaust and it fits with about a half inch clearance. From my initial impressions of the handling, well I am still :yesnod: . The Sol handled great before but it is exceptional now. Much flatter in the curves and less flex of the rear. I haven't got to really put it thru it paces yet as I have the PCM out and enroute to Westers for programming. Hopefully I will get to play :driving: and see how the performance and handling is this weekend. Later Hillbilly
I have solo mach exhaust will it fit? And will this make the front hold better in turns.. that is my problem the front just seams to slide.
Vendor
Yes, the Pro-beam has fit with every exhaust so far, Magnaflow, DDMworks, Billy Boat, SOLO, etc.
The installation of the Pro-beam makes for a crisper turn in and makes the back feel more planted, this along with a good alignment do wonders for the cars handling.
If i order now when should i expect del.
;) I finally got a chance to do a stress test on my newly installed DDM beam. Prior to the install, I was having problems with the rear end moving around in a circular manner when pushed hard on uneven pavement. Today I did over 100 miles and stressed it pretty well. It now drives dead straight and has no more wobbling on the rear end. It is a much tighter feeling car now. I am very happy. The best bang for the buck investment I have made yet on my GXP.
Good job guys.
Vendor
Good job guys.
Thanks! There was A LOT of testing put into the Pro-beam, and always great to hear how everyones installs go.
Thanks again for the order!
How much longer for the second batch to get to us?.
This is what i was told on 4-4-08
The next batch is in production already, we are expecting them in 3-4 weeks.
We did a slight modification to the Pro-beam after the first batch - One of our customers has the Thermal Research exhaust and the Pro-beam would not fit without a slight modification, so we were able to make a small modification to the brackets on the Pro-beam to fit that exhaust also. As far as we know now it will fit every exhaust out there now. Also after the initial batch of orders and all of the pre-orders we keep getting we had to substantially increase how many we are making.
I have a basic question. Is the Pro Beam better than the KappaSphere ReBar? Which makes the biggest difference in the handling characteristics?
1 - 20 of 116 Posts
