Differential Rebuild/Replace
I believe I am having some differential trouble. It is an 06, and from what I understand they have known differential issues. However, mine is not a whining noise that most complain about. It is more of a grinding and vibration, but only under certain conditions...for example cruising at ~2900 rpm and decelerating at ~2-2500 rpm. It is mainly noticeable in 3rd and 4th. I thought it was the clutch ... So I replaced that, but the noise is still there. However, the clutch did need replaced anyway. The stage 2 SC wore it down. What options are theoptions to repair/replace/upgrade the diff? With it being a known issue, would there be a warranty or recall repair to pursue through GM?
1) REPAIR - From what I understand rebuild kits are not available, but I believe some have had theirs rebuilt. Are rebuilds possible?
2) REPLACE - Will only a unit from an 06 fit? I know the torque bars started in 07.
3) UPGRADE - Are there any upgrades that be done to prevent future issues?
Lots of questions, but I trust the forum much more than I do my GM dealer. Ha! Thanks to all for any guidance!
