Well I finally put everything together today. It went much faster than I expected! To recap:
- Walnut blasted valves
- New Spark Plugs (gapped to 0.032, light coat of copper anti-seize, very light coat of dielectric grease on the inside wall of the boot)
- PAW Intake and TB spacer
- PAW TCM Tune (requires sending TCM to PAW)
I went to start the car and....drum roll....nothing! The engine doesn't turn over, nothing.
I reinspect everything, put a meter on the battery, it reads 12.5 volts.
I check the fuses; nothing obviously wrong here.
I perform the definition of insanity, per Mr. Einstein, and try to start the car several more times hoping for a different result.
There is no different result.
I'm embarrassed to admit the following...it then clicks with me....the TCM is still sitting in the shipping box I got from PAW.
I unhook the battery, install the TCM, reconnect the battery and sit in the driver's seat. I turn the key and subsequently have an engine that sparks to life.
An engine that coughs and runs rough. There is a "Reduced Engine Pwr" message staring at me. While the engines still running, it seems to clear up after about 8 seconds.
I turn it off and restarted, once again it runs rough and then clears up.
The thirds time I start the car it runs perfectly but still has the reduced engine per message. I let it idle for quite awhile.
I pull out my OBD2 reader and get the same message that it said on the car a year ago - Error.
I walk to my neighbors house whose a mechanic, since his trucks at home and ring his "Ring" doorbell. For the second time that I've ever rang his bell he doesn't answer.
Tomorrow I'll drive it to O'Reillys and try their reader and reset the code at the same time.
I've read here on the forum that it could be anything from a bad HPFP to an electrical gremlin.
I look forward to my O'Reillys trip....
Stay tuned...
Stay tuned...
