1 - 9 of 9 Posts
I just recieved my Solstice on Sunday and as soon as i left the dealership the driver's side head light went out!!!!!!!!!! :brentil: I drove it home anyway...cause ya know im not leaving it at the dealer, took it back the next day.."they said it was fixed" and later on the drive home it went out again. Has anyone else had a problem like this??? Any thoughts on how to get it fixed???
You are the first I can remember with this problem. Sorry no magic advice, other then going back to the dealership.
When you do go back, have them file a Field Product Report on what they may find and the fix.
Here is the thread on the Field Product Report:
http://www.solsticeforum.com/forum/showthread.php?t=8134
tampafl said:
I just recieved my Solstice on Sunday and as soon as i left the dealership the driver's side head light went out!!!!!!!!!! :brentil: I drove it home anyway...cause ya know im not leaving it at the dealer, took it back the next day.."they said it was fixed" and later on the drive home it went out again...
tampafl; When you say it "went out" and later "they fixed it". Do mean it blew and was replaced by the the service dept., or do you know? Were both high & low beams inoperable in that headlight?
They have now fixed the problem (I'll have to check with them tomorrow to see what exactly it was). Thanks for the replies though. For a better description of what was going on... It would turn on when you unlocked the car.. it would turn on with high beams.. and it would turn on when i first started it up - but after say 10 mins. of driving, and turning off the lights, when i turned them back on the driver's side would not come on, but would still come on for high beams..
By the way now that i have my car etc...etc. where do i notify my information for this site to update car # & location?
Driver's Headlight Intermittent
What did they find? The drivers side headlight on my car (both high and low beams) go out after the car is warm. After it cools, they work OK. Replaced the bulb, checked the fuses (one for each beam). All are good. Any ideas appreciated.
Sol Driving Member
I had a problem with the right side day-time running light/turn signal. The clips in the connector were not making full contact with the bulb. I bent the metal tab slightly and have not had a problem since.
Headlight Problem
I had the same problem back in March and posted a notice here on the Forum. The problem was diagnosed as a bad connector on the wire to the headlight assembly. The fix entailed a new wiring harness (three actually if you count the two incorrect ones that came in before the right one) which I thought was overkill when splicing a new connector to the wire apparently would have accomplished the same thing. My Sol has foglights that required a 15299544 harness and not the 15299543 that is for a Sol without the foglights.
Headlight Problem
Thanks 2late. Sounds like my situation exactly. It's going in the shop on Friday and I'll pass the info along to the tech.
I have a problem with my headlights for a while now it's really annoying i know i need a new wire harness becouse my stock is messed up burned i guess so the qustions is if i bring it back to dealer will they replace it fix it? do they have wire harness for hadlights? or i have to buy it? and i couldn't acctualy find wire harness anywhere the H13 one and the one i found is a conversion it's like the whole thing that costs 200 somthing dollars the cheapest one So i don't how to solve this problem
1 - 9 of 9 Posts
