1 - 3 of 3 Posts
Hello everyone. Noticed this today. Left rear of vehicle sits about half an inch lower then the other three sides. Tire pressure is correct on all wheels. Understand not entirely uncommon for drivers side of vehicles to sit a bit lower over time due to drivers weight. And, the drivers weight in these cars is right up against the rear wheel. I measured from ground to wheel arch. Car has 20,00O miles. Anyone care to confirm this? Not sure if I should be concerned or not. Thanks in advance.
That is not normal, check your shocks on that side, and also the springs.
Mine is the same, about 1/2 to 1/4 inch lower on drivers side in rear. Was at a body shop recently and brought it up and the guy told me that this was pretty common with gm's. Definitely would hurt to get under it and check out the suspension assembly.
1 - 3 of 3 Posts
