OK so after 4 or 5 attempts at getting the coolant lines installed I now have everything routed nicely minimizing any disruption to airflow around the engine. It also looks good.
Here are some photos.
I am going to have to pull everything back out and tighten up all of the hose ends and I need to add 3 more branches on the manifold and give that a new paint job. I still have to make all of the vacuum lines as those are all going to be AN as well. I am waiting for the last order of fittings to come in and I have to file down all of the barbs to make the nipples straight for a compression fitting will slide on. There are a lot of them that I have to file. Here is a list of all of them
cold side charge pipe next to the TMAP.
intake manifold
wastegate solenoid, 3 nipples
bypass valve solenoid, 3 nipples
front of the turbo
I believe that is all of them. I already have the m10x1.0 to 4an fitting for the wastegate.
What I am waiting on
1/4" hard line to 4an fittings
a single 3/4" hard line to 12an fitting (heater core)
#3orb to 4an for the bypass valve
1/8" NPT to 6an, surge tank connection at the manifold
1/8" NPT to 4an, wastegate coolant return at the manifold
Because of how populated the manifold is getting and how short it is I have to put a little bit of planning into what lines are going to connect where because all of the branches have to come off the manifold as elbows. I don't want to have to use extensions but I may have to on 3 of the branches to lift them up high enough so another branch will fit under it.
This is what I have going on
The expansion lines on the top have to stay on the top. those cannot be moved at all. They also have to be higher then all of the lines. so I can't move a 12an connection from the bottom of the manifold to the top of the manifold so it goes over the 6an connection. can't change that at all. I can probably move the radiator expansion. if air is in that line and the air gets pushed into the manifold it will eventually end up going into the line that goes to the surge tank. The surge tank most also be the closest line on the top coming form the head. All the lines attached at the top will be as far left as possible as this is going to give as much space as possible for bubbles in the coolant to rise to the top of the manifold where they will then go into the surge tank line.
I am going to take some measurements tomorrow to see how tall the extensions needs to be and if they make them in the sizes I need. I do have a limited amount of space under the manifold so I have to get it right.
