@wmf246 : The EBCM (Electronic Brake Control Module) is grounded at G105, which is located on the frame rail at the left front corner of the engine bay. Look all the way forward, below the headlight.
Also, regardless of the cause, if you have a warning light you should have a code. Otherwise you have a system problem that should be affecting more than what you are seeing.
I looked up your reader and did not find anything that specifically references chassis codes, so I wonder if you are able to read them.
From the main menu of the scanner you should have an option labeled "DTC Lookup". I would go there and try to look up C0110 which is the code for Pump Motor Circuit Actuator Stuck. If it will not allow you to switch the P to a C you will know that you cannot use that scanner for this problem.
