1 - 6 of 6 Posts
Just had my code read for my engine light warning and got P0011 which indicates intake cam timing advanced. Lights been reset and has stayed off. My mechanic says it was probably just a temp glitch like bad gas or dirt. Any one else dealt with this code number?
thanks for any feedback you can give me.
I would do a forum search for P0011.
Oh yes. Lot's of experiences with this one. If code went off, you're probably OK. If it continues to come on occasionally, replacement is fairly simple and inexpensive if you do it yourself.
I had the same thing about a month ago and had it read. Agree with BellaVerde in that if it onyl was once you're ok.
As the actuator fails, you may find it come on and go off on its own. My CEL would come on with a P0011 while using the engine to help brake going down hills, or under hard acceleration and would go off a few hundred miles later. I drove with a bad actuator for almost a year and noticed no performance changes, even after it got replaced.
1 - 6 of 6 Posts
