So I was under my car this morning investigating what I would call excessive drivetrain slop, like backlash. Started in the back thinking I would consider poly inserts for the differential if they were cracking. Worked my way forward and noticed just under the driver side engine mount is a bunch of black fluid all over. I did not know mounts were fluid filled, but after researching a bit I noticed there is such a thing and we may have fluid mounts? The fluid is all over, looks to have squirted out and leaking all over the chassis. Appears to have been doing this for some time as there are dark stains all over in that area. Does this make sense to anyone? I just don't want to look silly going to the dealer if this is not the case. It is certainly not motor oil, its more watery or thin and does not smell like motor oil and does appear to be coming from the mount. I'll snap some pictures later.
Any input is appreciated. Thanks.
