1 - 1 of 1 Posts
Good day all, first time posting.
I have a Pontiac solstice GXP 2007 with about 9k miles on it. Anyways got a check engine light, code PO 556 which is the pressure sensor for the Power Brake Booster.
106932
I order the part and it should be here very soon hoping its just that a bad sensor. however Taking a closer look at the 3 hoses that run from it one hose that goes under the engine moves a bit to freely. A closer look and i can see a white connector which in turn is connected to the hose. It rotates as I move the hose. Is this normal for this part to move? Can anyone of you who happen to have the gxp take a quick look and see if that is normal. The clamp seems to be in place correctly and maybe the rotation is normal?
1 - 1 of 1 Posts
