1 - 5 of 5 Posts
Hi.
I installed BW EFR 6258 turbo, and flashed ECM with Trifecta.
At frist time when I test-drive, my car ran well.
But while test-driving, suddenly he became slow and couldn't spool-up the boost. the rev raised slowly upto 3000rpm.
There're no error code, check engine light off.
Is this limp-mode?
I tried to reflash the ECM and pull the plug for 20min to escape from limp-mode. but it didn't work.
You may have a loose connection in one of your pipes..
Check for leaks in the system.
You should also contact Vince at Trifecta for some help and advice.
I checked for leaks, but can't find it.
All pipes seems to be right.
What symptoms could be happened in limp mode?
And how can I escape from limp mode??
Glad you got it sorted out.
1 - 5 of 5 Posts
