after reading the solstice/kappa/sky forums for a few days it looks like a Trifecta tune is in order
I have a low mileage 2007 manual transmission solstice GXP and am looking to do a few mods. Am in the Sacramento, CA area and where I live I’m at an elevation of 1200 feet. Gas over here is mostly 91 oct. seeing about 17PSI of boost at the moment.
I’m not going to race the car; just like to do a mild tune at about 300hp. on the flywheel, which from what I understand is not going to be too hard/rough on the engine.
From what I understand trifecta offers a ‘canned’ tune for $200 plus a $200 deposit for the cable. Now, I’m planning on keeping everything stock except perhaps a Werks intercooler, and a high flow cat ( plus 3 bar Map sensors if needed/beneficial.)
To determine if I would need just the canned tune or a custom/full tune, first a couple of questions to help decide which way to go..
Am Thinking of getting the Werks street version intercooler first (Dejon = out of business and not available any more, right?)
Would this aftermarket IC negatively impact the performance of the canned tune? Am thinking about getting this to have a better flow,cooler air in the manifold and have an IC that stands up to the increased boost. (Seen quite a few postings online of blown up stock IC’s… )
Will the Werks Intercooler piping be beneficial?
Are ‘Cooler’ spark plugs needed/ recommended? Will the tune likely make temperatures go up or down, under normal driving conditions?
Are the 3 bar MAP sensors needed or beneficial in combination with the trifecta tune? Stock 2007 MAP sensors go up to 23 psi, at least that’s what I’ve read a few times; will the canned tune go over this / what are the PSI numbers likely going to be for the canned tune?
Since I’m looking for a ‘mild’ tune and keeping the engine temperatures under control I was thinking about max 22 PSI on the turbo ; is this realistic?
cheers,Vincent
cheers,Vincent
