1 - 5 of 5 Posts
Another item I noticed since winter; door chime is faint. Hasn't died completely, radio still works (thinking of replacing stock speakers maybe for better audio), and no alternator/voltage issues. Battery was relaced approximately 1 year ago. I'm the same post-er with the rough ride all of a sudden. Thank you.
This TSB will assist in adjusting your chime volume. You will see that it applies to our cars as well.
"The radio is used to adjust the vehicle's chime level. To change the volume level of the chime, press and hold push-button 6 with the ignition on and the radio power off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold push-button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display.
Note: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected."
5/2/2021 So weird; maybe I have a short somewhere. Just more regular driving seems to have increased volume on door chime and stock radio seems a bit louder??
Stock radio can increase with speed if that setting is turned on.
1 - 5 of 5 Posts
