Thank you
@The_Ghost....
The 2 round things that stick up in top of the engine right at the front of the engine. right in front of the coil packs..
When you change them the wiring harnesses are keyed and will only plug into the solenoid they are supposed to. remove and install one at a time making sure the wiring harness plugs into the new one before you put it in. you will need to use several flat head screwdrivers to get the old ones out. typically the thinner the blade on the screwdriver the narrower it is so you need to have 3-4 different sizes.
After you take the single 10mm bolt out that holds the part, take the thinnest screwdriver and put it where the part meets the engine and only where the bolt flange is, that last part is extremely important. You may need to tap the back of the screwdriver with a hammer in order to get it to start going under.
Once it is under give the screwdriver a twist. Take that screwdriver out and put in the next size up and give a twist. each time you twist it is going to raise the solenoid up.
After you have done that with all of the screwdrivers it should be high enough where you can take an 8mm 1/4" drive socket and lay it on it's side next to the bolt flange. You are going to use the socket as the fulcrum for a lever. Use a flat head screwdriver and get the tip under the flange and the socket under the screwdriver about 1/2" away from the flange and then push down on the screwdriver slowly! DO NOT pop the solenoid all the way out. once you have it so it's lose remove the 8mm socket, you do not want it to roll down and fall into the hole. Doing the lever thing insures the old part lifts straight up.
before you put the new one in use a little oil from the old solenoid on the o-ring of the new one. then push the new one down into the hole. put the bolt back in and reattach the wires. and that's all there is to it.
It's a 10-15 minute job to change them at most. Probably take longer to get the tools together together.. You have to remove the engine cover to see the solenoids.
The process above is how it should be done, it ensures the solenoid lifts straight up. you do not want to have the thing tilt at all or pry up on it in a manner that will cause any kind of a sideways pressure on it. They can snap leaving a piece in the top of the engine. Follow the steps above and it would be next to impossible too have that happen.
