Hi there!
When I wash my Solstice I usually wash the top first, using 303's top cleaner. I'll then wash the rest of the car with car wash soap, etc. by hand. I don't believe using car wash soap would be a problem on the top, but I've always used dedicated top cleaner on it. I'm most worried about grinding dirt into the top. Admittedly I may be sensitive to that -- I had a white top on a car once, and it was a nightmare to keep clean (I swore them off after that). My Solstice's top is black.
I've thought a lot recently about getting a foam gun. There was a thread a long time ago that mentioned the foam gun, but that's been several years ago. Time for an update -- is the foam gun worth the $50-$100ish they cost, and will using it on the top cause any problems? I can't imagine it will but I thought I'd check with the group.
Thoughts?
Thoughts?
