Got a new foglight switch from ebay and it won't fit my sol. It seems there were two different switches manufactured. One (like mine) has a small indicator light in the switch and one does not. Thats not a big deal but they are NOT interchangeable because the wiring harness plug for one switch will not fit the other. Although the switches look exactly alike, the female socket in the switches are mirror images of each other. If your switch has the indicator light, be sure the new switch also has the indicator light or the plug won't fit properly.
Also found that if you have a fog lamp switch that sometimes doesn't work, you can remove the instrument cluster bezel, squirt some electrical parts cleaner in the guts of the switch from the backside without removing it from the panel, and it will heal itself!
